Version 2.2 | Published May 02, 2024 ©
Security Advisor
After installing the software, we recommend to:
Only allow authenticated users (Configure Service Host > Rest Server Config) or restrict the access to local access only.
Restrict listen to to the network interface being used.
Change the default port (9000).
Verify the log files of Service Host on a regular basis.
Disable Remote Access for WIBU Codemeter Webadmin and use SSL (Configuration > Basic > Webadmin).
Remove any unneeded services.
Note: Be aware that if more services of, for example, Channel Recorder are created, more network ports are opened.
Service Host is using the following network ports by default:
Service Host |
9000 (configurable) |
TCP |
Service Host configuration Web interface |
Channel Recorder (Basic Configuration) |
6180 (configurable) |
TCP |
Channel Recorder Communication port |
5210 (configurable) |
TCP |
MVCP protocol port |
Other Components |
427 |
TCP, UDP |
OpenSLP |
22352 |
TCP, UDP |
Codemeter |
