Version 2.2 | Published May 02, 2024 ©
Data Types
Booleans
Booleans are a data type with only two possible values; true or false. The Channel Recorder accepts YES, NO, TRUE, FALSE, ON, or OFF as Boolean values, where:
  • YES, TRUE and ON are positive values switching a flag On, and
  • NO, FALSE and OFF are negative values switching a flag Off.
Timecodes
Timecodes in Channel Recorder have the form <hh>:<mm>:<ss>:<ff>, where
  • <hh> represents the hour in 24 hour format,
  • <mm> is minutes,
  • <ss> is seconds, and
  • <ff> refers to the frame number, according to the frame rate.
    Example: A zero timecode looks like this: 00:00:00:00.
