Pilot Data Server Administrator Guide
Version PDS-9.1 | Published July 17, 2024 ©
Proxy Support
Pilot Data Server can be installed along with a proxy/reverse-proxy server. The proxy server must either populate the X-Forwarded headers or the Forwarded header in order for Pilot Data Server to serve the appropriate hostname, port and protocol in its responses:
Forwarded
X-Forwarded-Host
X-Forwarded-Port
X-Forwarded-Proto
Use a proxy server with the above headers configured. If the Forwarded or X-Forwarded headers are not configured, then the proxy server must be configured to pass the Host header it received from the client to Pilot Data Server.
Redundancy and Failover
Although Pilot Data Server has been designed without built-in redundancy, it does support being used with off-the-shelf third-party HTTP load balancers. As the name suggests, a load balancer's main function is to distribute requests among multiple servers. Multiple servers provide redundancy, and most load balancers come with an option to only route requests to servers that respond, which provides failover.
Both Barracuda Load Balancer ADC and HAProxy have successfully been used in front of Pilot Data Server.
Load Balancer Quick Setup
Quickly set up a HAProxy load balancer:
Prerequisites
Two (or more) hosts running Pilot Data Server, connected to the same database. They have host names pds1.example and pds2.example for the purpose of these instructions. Static IP addresses may be used instead.
A Linux host that turns into a load balancer. It has the host name proxy.example for the purpose of these instructions. This is the host used in the installation steps below.
Installation Steps
On the Linux host, install HAProxy with the command sudo apt-get install haproxy.
Edit /etc/haproxy/haproxy.cfg (for example with sudo nano /etc/haproxy/haproxy.cfg) and append the following lines:
frontend http-inbind :8177default_backend serversbackend serversserver server1 pds1.example:8177checkserver server2 pds2.example:8177checklisten statsbind :80mode httpstats enablestats uri / -
Restart HAProxy with the command sudo service haproxy reload.
Notes
After following the steps above, it should be possible to use proxy.example:8177 in place for pds1.example:8177 and pds2.example:8177. Check whether the setup works by opening http://proxy.example:8177/ in a browser. The Pilot Data Server index page should load.
The above configuration also provides a monitoring page at http://proxy.example/ that shows which Pilot Data Server hosts are responding. This does not tell you whether Pilot Data Server is working correctly, as hosts still respond when they cannot reach the database.
