Pilot Data Server Administrator Guide
Version PDS-9.1 | Published July 17, 2024 ©
Default Ports and Protocols
The table below showa all of the default Protocols and Ports used with Pilot Data Server.
HTTP
Name |
Default Value |
Comments |
Pilot Data Server |
http://pds-host:8177 |
The port used for HTTP is configurable in the DataServerConfig.ini file on %ProgramData%\Vizrt\Pilot Data Server. |
Script Runner |
http://pds-host:1981 |
Installed with Pilot Data Server and runs on the same host machine. The port used for HTTP is configurable in the file PilotScriptRunnerHostService.exe.config in the Pilot Data Server installation folder. |
Crop Service |
http://pds-host:8178 |
Separate installer that normally runs on the same host as Pilot Data Server. The port used for HTTP is configurable in the file PilotCropServiceHost.exe.config in the Crop Service installation folder. |
Graphic Hub REST |
http://gh-host:19398 |
Graphic Hub uses the same port for HTTP and HTTPS. |
Viz One |
http://vizone-host:80/thirdparty |
Preview Server |
http://ps-host:21098 |
REST VOS / GH Image Extension |
http://imex-host:19390/restvos/service |
The image extension UI can be accessed on http://imex-host:19390/imagelibrary/index.html. |
Viz Pilot Preview Port |
50008 |
Viz Engine preview port used for snapshot previews in Viz Pilot. |
Viz Arc MOS Panel |
http://arc-host:9004/mos-plugin |
PDS changelog notifications |
stomp://pds-host:9876/?destination=/changelog&lastKnownId=-1 |
HTTPS
Name |
Default Value |
Comments |
Pilot Data Server |
https://pds-host:7373 |
The port used for HTTPS is configurable from the Pilot Data Server Launcher. The service needs to restart. |
Script Runner |
https://pds-host:1982 |
Crop Service |
https://pds-host:8179 |
Graphic Hub REST |
https://gh-host:19398 |
Viz One |
https://vizone-host.example.com:443/thirdparty |
Preview Server |
https://ps-host:4443 |
No support for HTTPS. |
50008 |
Viz Arc MOS panel |
https://arc-host:9005/mos-plugin |
