Version 2.1 | Published October 06, 2017 ©
Supported NLE Systems
The list below is the current list of supported NLE systems that is within the scope of this document. Other versions are not officially supported unless it is specifically mentioned as part of this document.
The following systems are supported:
Adobe Premiere Pro
The Graphics Plugin for Adobe works together with Adobe Premiere Pro from version CS5 (including versions CS5.5 and CS6). This plugin works on both Windows-machines and Macs.
The Graphics Plugin for Adobe also works together with Adobe Premiere Pro Creative Cloud (CC). This setup has been tested to work on Windows-machines.
Note:
In addition to Adobe Premiere Pro, the Graphics Plugin for Adobe pluginsupportAdobe AfterEffects from version CS5.
Apple Final Cut Pro
The Graphics Plugin for Final Cut works together with Apple Final Cut Pro 6 and 7 (available in Final Cut Studio 2 and 3, respectively), and Final Cut Pro X. This plugin works on Mac-machines only.
Note:
There are separate installers for versions 6+7, and X.
Avid Media Composer and Avid NewsCutter
The Graphics Plugin for Avid works together with Avid Media Composer and NewsCutter. This plugin works on both Windows-machines and Macs.
The plugin for Avid has been tested with Avid’s Media Composer and NewsCutter; however, all systems supporting the Avid Extensions (AVX) 2.0 System Development Kit (SDK) should work. The following Avid products have AVX2 support:
Avid Digital Studio (DS)
Media Composer (Older Release and Post Adrenaline HD release that can run software only), Media Composer Adrenaline, and Media Composer Adrenaline HD
NewsCutter, NewsCutter FX, NewsCutter XP, and NewsCutter Adrenaline (FX)
Symphony and Symphony Nitris
Xpress, Xpress Pro, and Xpress Pro HD
Separate Graphics Plugin for Avid installers apply for Windows 32- and 64-bit systems. The 32-bit Graphics Plugin version works together with Media Composer 5 and NewsCutter 9, whereas the 64-bit version works with the new Media Composer 6 and NewsCutter 10.
Note:
Avid Liquid, previously known as Pinnacle Liquid, has been discontinued byAvid, and is currently not supported by the Graphics Plugin.
Quantel Rio
The Graphics Plugin for Quantel works together with Quantel Rio 4.3, or later. This plugin works on Windows-machines only.
Note:
Version 2.0 of the Graphics Plugin supports earlier versions of Quantel QEffects/Rio (version 4.2).
The Graphics Plugin for Adobe works together with Adobe Premiere Pro Creative Cloud (CC). The system is supported by Windows 8.1.
