Version 2.1 | Published October 06, 2017 ©
Effect Plugins
Effect plugins, such as RFxSmoke, works in such a way that particles are emitted from a certain point, and then moved in a random order in some direction until they eventually fade away. The output of this random particle movement may be distorted when played out as part of the Graphics Plugin workflow. Hence, it is recommended to use such effects with caution when designing for NLE.
