Version 2.1 | Published October 06, 2017 ©
Log Files
Logging is performed by the Graphics Plugin, and the different applications that the Graphics Plugin integrates with. The following paragraphs describe the different log files, their log levels, and where they are stored.
The Graphics Plugin generates log files that are located in the directory specified by the Graphics Plugin (see below).
The Windows-based log files are placed in the following directory;
%APPDATA%/Vizrt/VizNLE/Logs
viznle-log-<date_time>.txt
nleconfig-<date_time>.txt
vcp_ax_nle.log
trio-<date_time>.log
Note:
The log directory can be modified from the Graphics Plugin configuration tool for Windows.
The Mac-based log files are placed in the following directory;
~/Library/Logs/VizNLE/
viznle_log--<date_time>.txt
VizNLEConfig--<date_time>.log
VizNLE_Editor--<date_time>.log
The Graphics Plugin related log files, including Viz Trio and Viz Pilot log files, are by default placed at %APPDATA%/Vizrt/VizNLE/Logs.
The location of the Graphics Plugin log files can be modified from the Graphics Plugin configuration tool, under the Plugin settings view. The text in the Plugin log directory box defines the folder where the log files should be placed. To define a new folder for the log files, type a new path in the text box.
The path for the Viz Trio and Viz Pilot log files can be modified from the Graphics Plugin configuration tool, under the Viz Trio NLE and Viz Pilot NLE settings view respectively. By default, these log files are defined to be put in the same folder as the Graphics Plugin specific log files, by using the -logfile-path LOG_PATH command in the options text box (LOG_PATH refers to the Plugin log directory setting).
To place the Viz Trio and Viz Pilot log files in a folder separate from the Graphics Plugin log files, replace LOG_PATH in the options text box with a folder name.
Note:
Plugin log directory does not apply for Graphics Plugin Editor.
