Version 3.1 | Published July 11, 2018 ©
Licensing the Graphic Hub
This section describes how to license Graphic Hub using a Graphic Hub Sentinel license dongle or WiBu License, which is required for Graphic Hubs running in Multiuser, Main or Replication mode.
For more information on how to apply licenses, check the Vizrt Licensing Guide in the Vizrt documentation center. For details on how to setup which licensing system will be used by the Graphic Hub.
Using a Graphic Hub Sentinel license dongle on physical machines
Using a Graphic Hub Sentinel license dongle on an ESXi Virtual Machine
Using a Graphic Hub Sentinel license dongle on a Virtual Machine workstation
Using WiBu Licensing of Graphic Hub version 3.1.0 on physical machines or virtual environments
Connect the USB dongle to the machine.
Install the Graphic Hub with the dongle driver.
Choose the Sentinel system in GH Terminal Configuration → ADVANCED SETTINGS → License Settings.
Connect the USB dongle to the machine where the ESXI is running.
From vSphere client, right click on the virtual machine where Graphic Hub is going to be installed.
Click on edit settings, in Hardware tab click add, another window will popup, choose USB controller and click next, click next in the next window and finally click finish in the window after.
From Hardware tab click add, another window will popup, choose USB device and click next, the USB dongle will appear in the next window, choose it and click next, then click finish in the next window.
Connect the USB dongle to the machine where the virtual machine workstation is running.
Once the dongle is connected, a window will popup in the VMware workstation window stating that the connected dongle can be connected to the virtual machine, click OK
Choose the Sentinel system inGH Terminal Configuration → ADVANCED SETTINGS → License Settings.
Graphic Hubs can be licensed with a special WiBu License. The required WiBu Runtime Software (CodeMeter Runtime 6.60a) comes with the Graphic Hub Bundle installer and is mandatory for the modes Multiuser, Main and Replication.
If a WiBu License is found and bound it sticks to this license container and can only be changed by a restart of the Graphic Hub. The same applies for switching to the Sentinel dongle, which also can only be done by restarting the Graphic Hub.
License expiration messages are logged to the Graphic Hub Journal as usual (alerts, expiration warning 30 days prior to expiration and if license is expired or invalid). The WiBu license information (license id, license server, container id) is logged to the Graphic Hub log file upon status changes and the Graphic Hub WiBu license application ID is 1300000.
Setup a WiBu license container as described in the Vizrt Licensing Guide in the Vizrt documentation center.
Install the Graphic Hub with the CodeMeter Runtime.
Choose the WIBU system and the appropriate location of the license container in GH Terminal Configuration → ADVANCED SETTINGS → License Settings.
To verify if the license is applied correctly, please check either the
GH Terminal Graphic Hub license information (reached via About → Graphic Hub license in GH Terminal):
GH Terminal Graphic Hub log file (reached via Show GH Log in GH Terminal):
GH Manager license information (reached via Info → License info... in GH Manager):
GH Manager monitor (reached via Tools → Monitor servers... in GH Manager):
License changes (e.g. setting a new license key) are not supported for WiBu License. Setting a new license string does not work in GH Terminal and GH Manager, since these changes must be performed in the CodeMeter Runtime.
