Version 3.1 | Published July 11, 2018 ©
Backup and Restore
The Backup menu shows the backup, restore and data recovery options. As the Graphic Hub server cannot be backed up or restored while running, the server must be shut down to enable changes to the configuration settings.
The internal backup and restore operations of the Graphic Hub is an incremental process. If one backup or restore operation succeeds, all subsequent operations copy the difference from the successful backup/restore to the current operation. Restore points are created to accomplish this process.
The first restore point holds information about the original data directory.
The second point holds information about changes from the startup to the first backup.
The third point holds information from the first to second backup, and so on. If no changes have been made since the previous backup, the Graphic Hub will not create a new restore point.
Example: The first backup finished successfully at 01.01.2009 00:00:10 and the second at 01.01.2009 12:00:00. Between the backups, one scene was modified; “MyScene”. The latest restore point would then only contain data regarding this scene. If restoring to the previous point, only “MyScene” will reset to its status at 01.01.2009 00:00:10.
There are two kinds of backup, internal and external, both of which are configured in the Graphic Hub Terminal. Make sure to shut down the Graphic Hub before performing backup configuration.
Internal Backup
Internal Backups are incremental backups as described above. It is possible to limit the number of restore points after a backup. Reducing the amount of restore points vastly reduces the amount of disk space required on the server.
External Backup
External backups are executed via a command line call of the Graphic Hub Terminal. It is a full backup, and requires the creation of a batch file for execution. Output from the batch file to the console is visible in the Terminal logging window.
This example batch file copies the data directory to C:\COPY:
ECHO
off
echo
Starting
copy
of data
dir
"%~1"
IF [%1] == [] (
echo
ERROR: NO DATADIR
SET
EXIT 1
robocopy
"%~1."
"C:\COPY"
/MIR /
COPY
:DAT /DCOPY:T
echo
"robocopy exit code: %ERRORLEVEL%"
IF %ERRORLEVEL% LEQ 7 (
echo
FINISHED SUCCESSFULLY
EXIT 0
) else (
echo
ERROR DETECTED
EXIT 1
Backup Configuration
This section details the parameters and configuration of the backup and restore system.
Tip: Backup can only be configured when the Graphic Hub server is not running.
Go to Backup -> Backup -> Configuration to open the Backup configuration window:
Disabled: Backup disabled.
Internal Backup: Click to make internal backup active.
Backup Directory: Enter a backup directory path. Only local drives are allowed as backup directory path.
Cleanup restore points: Check this checkbox to enable limits to the number of stored restore points. All restore points beyond the maximum will be deleted. This can save considerable hard disk space.
Maximum restore points: Set the maximum number of restore points.
External Backup: Click to activate external backup.
Batch file path: Set the path to and name of the batch file to execute.
Note: As Graphic Hub Terminal runs as a service under the SYSTEM account, it cannot access network drives mapped by another user. Make sure that the destination path for the external backup is a local drive.
Automatic Backup Settings
This is used in combination with a shut down task to do periodic automated backups:
Automatic backup after successful shutdown: When checked, an automatic backup on server shutdown is performed.
Start after backup: When checked, the server is automatically started upon completion of the automatic backup.
Note:Start after backup is only applicable when shutting down the server through the Graphic Hub Manager or when the server is shut down by Scheduled Tasks.
To Configure Backup
Shutdown the Graphic Hub server if it is running, in accordance with the Graphic Hub Shut Down procedure.
Open the Graphic Hub Terminal.
Go to Backup -> Show Configuration.
Select the required backup type, Internal or External.
For Internal Backup:
Select Internal Backup.
Enter the Backup Directory path.
If required, check the Cleanup restore points checkbox and set the maximum number of restore points.
For External Backup:
Select External Backup.
Enter the Batch file path.
Select as required:
Start after backup.
Click Apply to perform the backup operation.
Perform Database Backup
This section details the backup of a Graphic Hub database. The procedure depends on whether an internal or an external backup has been configured.
To Do an Internal Backup
Select Backup -> Create backup now.
The backup is created in the directory specified in the backup configuration, as indicated by the Create backup now link.
To Do an External Backup
Make sure that the a batch file has been created and is available.
Select Backup -> Create backup now (External Backup).
Restore Files
To open the Restore Points panel, open the Graphic Hub Terminal and select Restore from the Backup menu. The panel contains information about the restore points available according to the current backup configuration, such as the date and time the restore point was created, how many files it contains, and the location.
The Restore Points panel is accessible when the Graphic Hub is running. However, it is not possible to perform a restore task while the Graphic Hub is running.
Restoring Files: Best Practices
When files are restored, observe these best practices:
Data directories: It is not recommended to restore files to an already existing data directory. Create a new directory and restore the files there. Then start a new configuration of the Graphic Hub Server using the location of the restored files as data directory.
To Restore Backup Files
In the Graphic Hub Terminal, go to Backup -> Restore.
Select which restore point to restore.
In the Restore directory field, enter the location which the files should be restored to, or press the browse button to browse to the desired location. New directories can be created either by typing in a non-existing path in the Restore directory field, or by right clicking the directory tree while browsing and selecting New folder.
Caution: Do not restore files to an existing data directory, as this will overwrite any existing data. Instead, create a new directory and restore the files there.
Click Restore. The Restore progress window appears, providing information about the restore process.
Safe Mode
The Graphic Hub Terminal should be started in Safe Mode if the database has crashed and needs to be restarted.
Rebuilding the database in Safe Mode can take several hours, depending on the amount of data that needs to be reconstructed. The recovered directory cannot be accessed by clients such as Viz Artist. It can only be accessed by a system administrator using the Graphic Hub Manager.
Caution: Do not use Safe Mode for valid data directories.
To Prepare for Database Repair
Back up the current data directory.
Close all Graphic Hub Deploy Agent connections to the server.
Close all Graphic Hub Rest Agent connections to the server.
Make sure that the instance is not part of a Graphic Hub Cluster environment.
Make sure that the latest version of Graphic Hub is installed.
To Start Graphic Hub Terminal in Safe Mode
Prepare the repair procedure as described above.
In the Graphic Hub Terminal, go to Backup -> Data recovery (Safe Mode):
Carefully read the information, then click Start to proceed.
Check the configuration settings, then click Start.
This begins the rebuild process. Rebuilding a large database may take several hours to complete.When the data has been rebuilt, the Graphic Hub Manager will contain a folder called RECOVERED_AT_YYYY-MM-DD_HH_MM_SS. The date and time in the folder name serves as a timestamp for the last modification.
Successful Restore Operation
The database has been successfully restored when:
The red console panel shows that the server is up and running.
All processed files are listed in Reports.
Files can be viewed in the Graphic Hub Manager.
IMPORTANT! A Graphic Hub server in a production environment must never run in safe mode. Safe Mode is only for restoring a corrupted database. This instance can now serve as a source for rebuilding an empty destination database through the DDC functionality (see Graphic Hub Deploy Agent).
