Viz Trio User Guide
Version 4.2 | Published April 02, 2024 ©
Viz Trio Log Files
Info: The Viz Trio logfiles can be found on: C:\Users\USER\AppData\Roaming\Vizrt\Viz Trio.
Viz Trio Log Levels
Viz Trio Log Levels can be specified to define the level of detail. For example, log level 0 provides information about critical errors only, while log level 9 provides information about a wide range of events.
Specify log levels in the General section of Configuration:
Loglevel 0: Only error messages are logged.
Loglevel 1: Warning messages are added.
Loglevel 2: Timer messages are added. These show the amount of time different operations take in the program.
Loglevel 5: Status messages are added. These show ordinary program events such as "page loaded", "page taken", and so on.
Loglevel 9: All commands sent to the Viz Engine rendering process are added.
Tip: Messages on log level 0 and 1 (error and warning messages) can also be viewed in the Error Messages Window.
Caution: In many cases it may be beneficial to set a low Media Sequencer Logging level, preferably to 0, since a high level of logging might affect performance when running in a production environment.
Changing Log Level
Click the menu option File > Configuration to open the Viz Trio Configuration.
Select General from the User Interface section.
In the Log level box, enter a log level according to the available Viz Trio Log Levels.
Changing the Log File Path
Click the Config button in Viz Trio’s main window to open the Viz Trio Configuration.
Select Paths from the User Interface section.
In the Logfile path box, enter the path to where the log files should be located from now on.
