Viz Trio User Guide
Version 4.2 | Published April 02, 2024 ©
Main Menu
The main menu at the top of the main window provides easy access to functions and workflows:
A brief description of the main menu sections is listed below. For certain menu items, a more detailed explanation can be found later in this chapter.
File
Option |
Function |
Open Show... |
Show a directory panel to open a TrioShow. |
Open External Playlist... |
Show a directory panel to open an external playlist. |
New Page View... |
Add a new pageview. |
New Show Playlist... |
Add a new playlist. |
Configuration |
Show the Configuration window where you configure Viz Trio. |
Show Properties |
View and configure properties for a TrioShow. |
Import Viz Engine Archive... |
Import Viz Engine Archive (.via) files from disk and re-import any affected templates in the current show. |
Import Show Archive... |
Import a TrioShow(.trioshow file) from disk. |
Export Show Archive... |
Export Show to disk as .trioshow file. |
Export Selected Pages Archive... |
Export Show with only selected pages including associated items, see Export Selected Pages Archive. |
Slave Mode |
Set Viz Trio in Slave Mode, see Slave Mode. |
Quit |
Quit Viz Trio. |
Page
Option |
Function |
Save |
Save the current page you're working on. |
Save As... |
Save the current page you're working on with a new name. |
Rename... |
Rename the current page you're working on. |
Change Template... |
Change the template for a page. |
Refresh Linked Data |
Asynchronously refresh the data for a page linked to a feed. |
Reimport |
Reimport the template design for a page. |
Delete |
Delete the currently selected page. You are asked for confirmation. |
Delete All |
Delete all pages. You'll be asked to confirm. |
Save to XML... |
Save page to an XML-file on disk. |
Load from XML... |
Load page from an XML-file on disk. |
Print/Save Snapshot... |
Take a Snapshot, which can be printed or saved to disk. |
Move to Number... |
Move page to a specific number. |
Move with Offset... |
Move page with offset. |
Copy to Number... |
Copy page to a specific number. |
Copy with Offset... |
Copy page with offset. |
Playout
Option |
Function |
Take |
Performs a direct take on the selected page. |
Pause |
Pauses the current element. |
Continue |
Continues the animation on the selected page, or any page that is loaded in the same transition logic layer as the selected page. |
Out |
Takes out the selected page, or any page that is loaded in the same transition logic layer as the selected page. Hard cut. |
Cue |
Prepares the clip for playout so the first frame is ready in the player. |
Cue Append |
Prepares the clip for playout. The clip starts automatically when the current clip ends. |
Take and Read Next |
Takes the current element and reads the next one. |
Cleanup Channels |
Cleans up the renderers (Viz Engines) currently in use by the open show. Asks for confirmation. This frees up renderer memory and realtime capacity. See Cleanup Channels. |
Initialize Show on Channels |
Loads the selected show on the program and preview renderers. See Initialize Channels. |
Initialize Show on Local Preview |
Loads the selected show on the Preview renderers. See Initialize Channels. |
Update on Program |
Updates on Program renderer without reloading or rerunning animations. Only for Transition Logic scenes. |
Update on External Preview |
Updates on External Preview renderer without reloading or rerunning animations. Only for Transition Logic scenes. |
Clear Program |
Takes out the scene on Program renderer, but does not clean up the renderer (scenes remain in memory). |
Clear external Preview |
Takes out the scene on Preview renderer, but does not clean up the renderer (scenes remain in memory). |
Start Scroll |
See Scroll Control. |
Stop Scroll |
Continue Scroll |
Arm Current |
See Arm and Fire. |
Arm Selected |
See Arm and Fire. |
Unarm Current |
See Arm and Fire. |
Unarm All |
See Arm and Fire. |
Fire All |
See Arm and Fire. |
View
Option |
Function |
Export Mode |
Toggle. Enable Viz Trio to operate in export mode. |
Tabfields |
Toggle. Enable tabfields. |
Commands |
Show the command window. In this window you can execute Viz Trio macros and commands using a command-line (cli) interface. |
Errors |
Show the error message window. |
Running Carousels |
Show the task window where all running tasks in the active profile are displayed. |
Refresh Thumbnails |
Force refresh of all thumbnails. |
Restore Default Layout |
Stacks and docks the main windows (Templates, Page List and Tab Fields) and cascades all other window in undocked mode. |
Lock Layout |
Prevents accidental undocking of window. It is still possible to resize and dock floating windows. |
Tools
Option |
Function |
Viz Artist |
Switch to Viz Artist. Viz Trio keeps running. While in Artist, click the Viz Trio button to return to Viz Trio again. See Viz Artist Mode. |
TimeCode Monitor |
Start the TimeCode Monitor. See TimeCode Monitor. |
Datacenter |
Start the Datacenter application if installed on localhost. See Datacenter in Viz Trio. |
Help
Option |
Function |
View Help |
Show help and documentation. |
Legal Notices |
Information about third-party code libraries. |
Trio Licensing |
Opens the Viz Trio license dialog box. |
About... |
Displays which Viz Trio version and build that has been installed on your machine (essential information to attach when reporting issues to Vizrt), Credits and Legal Notices. |
