Viz Trio User Guide
Version 3.2 | Published June 29, 2021 ©
Editing Multiple Elements with a Single Value
Use the same field identifier for multiple control plug-ins; two or more fields will then be handled as a single editing element and will receive the same value.
Note: This can be used with a bar that scales and a text label that shows its value, for example. The scale value and the text can then be set in a single operation, ensuring that there is no mismatch between the bar size and the written text value.
