Viz Mosart User Guide
Version 4.1 | Published July 09, 2021 ©
Skipping a Story Element
The next story element can be skipped with the SKIP NEXT command (default: F9), making them disappear from the GUI. The element following the skipped element is then cued in preview. Skipped element actions can be reversed with the UN-SKIP NEXT command (Default: SHIFT+F9), making them reappear in reverse order. Once you have progressed beyond the skipped item in the running order, it is no longer possible to bring it back with UN_SKIP NEXT.
