Viz Mosart User Guide
Version 4.1 | Published July 09, 2021 ©
Changing Template Sets
The currently loaded template set in AV Automation can be changed directly from the Viz Mosart GUI. To do so, use the Studio Setups menu and select the desired template set from the pull-down menu.
