Viz Mosart User Guide
Version 4.1 | Published July 09, 2021 ©
Looping Part of the Rundown
You can loop a part of the rundown, by setting a loop start and a loop end point in the rundown. The loop start and end are marked with 2 vertical white dots (see image below).
To set a loop start you can either:
Set the loop in by right-clicking on the item you want to start loop and selecting Loop > Start.
Use a STORY_ACTION LOOP_START control command to set the Loop Start item as the first item in the selected story.
To set the loop end point you can either
Set the loop out by right-clicking on the item you want to start loop and selecting Loop > End.
Use a STORY_ACTION LOOP_END control command to set the Loop End item as the last item in the selected story.
Auto-take
When entering the first item in a loop, Viz Mosart goes into auto-take next mode.
To exit auto-take mode use the control command AUTOTAKE.
If the loop is cleared using the loop clear command the autotake will also end.
Moving a Loop
To remove a end loop point, left click the loop point and select Loop > End to remove it.
Autotake continues while you are moving the point. -
Left-click the new position and choose Loop > End (or use a shortcut as described above).
The same procedure can be done for Loop > Start.
If the Loop > End point has been reached without a valid Loop Start point above it in the rundown, the next item is set to the first story in the rundown.
Stopping the Loop
To clear the loop, left-click and select Loop > Clear.
This stops the auto-take. Removing both Loop Start and Loop End continues the auto-take.
