Viz Licensing Administrator Guide
Version 2.1 | Published December 22, 2020 ©
Introduction
Vizrt is introducing a new software protection program that replaces node-locked licensing with a more flexible technology: WIBU Systems and a License Portal. This document guides you through the different self-service options and processes.
Key Benefits of this Software Protection Program
  • You can choose between:
    • Conventional dongles that allow you to use your Vizrt license on different systems.
    • Dongle-free license activation on individual, physical machines where a file container that holds the license for your Vizrt software is installed on the system.
    • Some Vizrt products will offer a License Server option in the future, where licenses for those products will be kept centrally and can be checked out by or assigned to individual machines for a period of time. On-premise license servers should be operated with conventional dongles. Cloud license servers can be operated with software containers.
    • Several self-service options offer more independence and eliminate international response times.
When Is the Software Protection Program Effective?
This software protection program is implemented in Vizrt software as part of major new releases. Prior versions covered by software protection can continue to run on the node-locked licensing. The License Activation chapter describes when you should use the License Portal.
