Viz Licensing Administrator Guide
Version 2.1 | Published December 22, 2020 ©
Helpful Videos
Vizrt has created video tutorials to help you perform the following tasks:
Transferring Valid Licenses to WIBU: How to transfer a Sentinel Dongle license to a WIBU License via the Vizrt License Portal.
Configuring Vizrt Software to Work with WIBU: How to set up Viz Engine, Viz Graphic Hub, Viz Tracking Hub, Viz Arc and Viz Libero for WIBU.
License Activation - Offline Activation: How to activate a license on a system without an internet connection using the Offline License Activation process.
Manually Creating a Receipt File: How to manually create a receipt file using the CodeMeter Control Center.
Maintenance Period Update: How to update the WIBU Licensing maintenance period. This tutorial covers the basics on how the maintenance period works and how the update is done.
License Server Installation, Configuration and Use: How to install and configure a license server. This tutorial also takes a quick look at license monitoring and configuration from a client perspective.
