Toolbar
New Map Template: Allows you to create a new map template (see Getting Started).
Open: Allows you to open existing map template files.
Save: Saves the map template file.
Save As: Allows you to save the map template file as a new file.
Refresh: Refreshes the thumbnails. Refreshing thumbnails must be done after manually editing a Map Builder generated scene and when re-launching the Map Builder as all thumbnails of maps (Base Map, Destinations and Orientation) are lost. To refresh them, click the Refresh button in the toolbar or press the F5 key.
Menus
File: Contains the same functions as the Toolbar, as well as Exit.
Tools: Contains:
Refresh thumbnails.
Map Server Settings (Viz World Server host name).
Option to enable/disable the tooltips.
Help: Contains links to the About information and the Viz World User Guide.
