When launching the Map Builder, you are presented with the following options:
Navigator: Builds a scene with one starting point and up to 32 destinations.
Focus on Map: Creates a static scene with a base map only. Can only be used with flat geometries.
1 Destination: Builds a scene with one starting point and one destination.
Map Object: Builds a scene with one starting point and one destination. The window option is used so that the map only uses part of the screen.
Open: Opens existing map template files.
