The Videowall Editor (VW Editor) is the part of Studio Manager that describes the LED walls of a
studio: where each wall stands, how big it is, what shape it has — and which Viz Engine renders it.
From that description Studio Manager builds the wall geometry directly in the videowall engine's
scene, so the engine's output lines up with the physical panels.
Everything in this chapter happens in the 3D studio view: a wall is an object in the same studio
space as the cyclorama, the cameras and the tracking origin. All values are in centimetres,
measured from the studio origin, with Y pointing up.
Setup
What you need
Viz Engine
One engine per videowall system, reachable from Studio Manager and on air.
Tracking Hub
A running Tracking Hub with a videowall service per engine.
GFX channel
A free GFX channel on that engine, used as the projection texture of the walls.
Studio Manager never writes into the engine's scene blindly: after every Create Wall it reads the
scene tree back and reports which wall containers really arrived. If a step below is missing, the
status line under the buttons says which one.
Adding the videowall service
The videowall service is the route from Studio Manager to the engine. Without it, walls can be drawn
in the editor but nothing reaches an engine.
  1. Open the Topology view.
  2. Right-click in the service area and choose Add video wall service.
  3. Select the new service and fill in its properties:
    • IP — address of the Viz Engine that drives the wall (default 127.0.0.1).
    • Port — the engine's data port (default 3000).
    • Command port — the engine's command port (default 6100). Studio Manager uses this port
      directly to create the wall geometry and to read it back.
    • Wall Group — the videowall system this service feeds, see below.
  4. Activate the service.
Wall groups — more than one videowall engine
A wall group decides which engine a wall is sent to. There are four groups, numbered 1 to 4, and
everything starts in group 1.
  • Every wall is in exactly one group (drop down in the wall's header in the editor).
  • Every videowall service is in exactly one group (service properties).
  • Tracking Hub sends a wall only to the services in the same group.
Groups are exclusive: there is no service that receives everything, and no wall that goes everywhere.
A group may hold one videowall service — mirroring the same wall onto two engines is not
supported. Both drop downs name a group after the service in it (for example "2 — 10.0.0.31", or
"3 — no service"), so you pick an engine rather than a bare number.
A configuration that never touches the groups has everything in group 1 and behaves exactly as it did
before wall groups existed.
{info}
A wall in a group that no service is in is sent nowhere. The editor warns when you move a wall
into such a group, and the settings panel shows the engine count next to the group selection.
{info}
What Studio Manager builds in the engine
Create Wall replaces the scene on the videowall engine and rebuilds every wall of the selected
group in it. Per wall it creates:
  • a top-level container named after the wall (for example Backwall1, OneCornerWall2), carrying a
    Virtual Window whose projection texture is GFX<n> — the GFX channel chosen in the settings
    panel;
  • one child container Panel (or Panel1, Panel2, … for multi-segment walls) with a
    MultiPanel geometry that carries the actual shape.
The wall is therefore a window into whatever is playing on that GFX channel. Playout, AR and the
built-in test scene all arrive through that channel.
{note}
Changing the GFX channel takes effect on the next Create Wall, not immediately.
{note}
The editor panel
The VW Editor lives in the editor column on the right of the 3D view, below the Cyc Editor. Its
header carries the panel title and a ... button that opens the videowall settings — reachable
whether the editor is expanded or collapsed.
Adding a wall
The four buttons at the top of the panel add a wall of that type:
Button
Wall type
Panels created in the engine
Back Wall — one flat panel
1
One Corner — two panels meeting in a corner
2
Two Corner — a back wall with a left and a right return
3
Curved — a curved/arc wall
1 (tessellated into segments)
At most 5 walls can exist at the same time. Above 3 walls Studio Manager warns that render
performance may suffer and lets you cancel; the wall is still allowed.
The wall list
Each wall appears as a collapsible entry. Its header carries:
  • the wall name (Backwall 1, OneCorner 2, …) — derived from the type and the wall id;
  • the wall group drop down — changing it moves the wall to another videowall system: the wall is
    deleted on the old group's engine and created on the new one;
  • the remove button (X) on the right, which asks for confirmation;
  • in advanced mode, the per-wall T (send targets) and detect buttons — see
    Advanced mode.
Colour coding. Each wall entry is tinted: the group picks the hue (1 blue, 2 orange, 3 green,
4 purple) and the position within the group picks the shade, lightest wall first. The same tint is
used for the wall in the 3D view and for its marker in the test room, so a wall can be traced from
the list to the studio view to the engine. Moving a wall to another group visibly changes its family.
Editing and when the engine is updated
Every value in a wall's panel is applied to the 3D view immediately and forwarded to the engine as it
changes, so dragging a slider moves the real wall live. Only the parameter that actually changed is
sent.
The full wall definition — the thing that is stored in the configuration — is pushed once you let
go of the control (and debounced for keyboard input), so a drag does not write hundreds of
configuration updates. Walls survive a configuration reload with their ids and groups intact.
Nothing at all is sent while the videowall service is stopped; those updates are skipped, not
queued. Start the service and use Create Wall to bring the engine back in line with the editor.
Wall geometries
Every wall type shares the same basic frame:
Field
Meaning
Position X / Y / Z
Anchor point of the wall in studio coordinates, in cm.
Rotation
Rotation around the vertical (Y) axis, in degrees.
Height
Height of the wall in cm (10 – 10000).
The type-specific fields are:
Back Wall
A single flat panel.
Field
Meaning
Width
Width of the panel in cm (10 – 10000).
Height
Height of the panel in cm.
Floor Mode (X/Z)
Lays the panel flat into the floor plane. The Height field then becomes Depth (Z), because the second dimension now runs along Z instead of up. Use it for LED floors.
One Corner
Two panels meeting in a corner — an L-shaped wall. The position is the corner (joint) itself.
Field
Meaning
SideOne
Length of the first leg in cm.
SideTwo
Length of the second leg in cm.
Height
Height of both legs.
Angle
Opening angle between the two legs, 0 – 180°. 90° is a square corner.
Orientation
Left or Right — which way the wall folds away from the corner.
Two Corner
A back wall with a return on each side — a U-shaped wall of three panels.
Field
Meaning
Back Wall
Width of the centre panel in cm.
Wall Left / Wall Right
Length of the left and right return in cm.
Height
Height of all three panels.
Angle Left / Angle Right
Opening angle of each return relative to the centre panel.
Curved
One curved panel, tessellated into straight segments.
Field
Meaning
Width
Chord width of the arc in cm.
Height
Height of the wall.
Segments
Number of straight segments the curve is built from, 1 – 100. More segments = smoother curve, more geometry.
Angle
Opening angle of the arc, −90° to +90°. 0 is flat; the sign decides which way it bows.
Orientation
How the panel is anchored: Geometry centres the arc on the entered position, Segment anchors it on its left edge.
Geometry mode and corner mode
Every wall type can be described in two ways, switched with the Mode toggle button at the top of
its Wall tab:
  • Mode: Geometry — the wall is described by the fields above (position, rotation, width, height,
    angles). This is the normal way to build a wall from its dimensions.
  • Mode: Corners — the wall is described by the absolute world coordinates of its corner
    points. Each corner gets an X / Y / Z box. Use this when the wall is not a clean rectangle, when
    it is tilted, or when the corners were measured in the real studio.
Switching to corner mode seeds the corners from the current geometry, so a wall built with the
dimension fields starts corner mode from exactly the same shape and can be nudged from there.
Wall type
Corners in corner mode
Back Wall
4 (bottom-left, bottom-right, top-right, top-left)
One Corner
6 (far / joint / far, bottom and top)
Two Corner
8
Curved
6 (left, middle, right — bottom and top) plus a Segments field
In corner mode the coordinates are sent to the engine as they are and the panel's own transform is
reset, so the wall sits exactly where the numbers say.
NDI preview
Each wall can show a live NDI stream on its surface in the 3D view, so the studio view shows what
the wall is actually playing instead of a grey panel.
  1. Tick Enable NDI on the wall's Wall tab.
  2. Pick a source from the drop down; the ⟳ button re-scans the network for NDI sources.
This is a preview inside Studio Manager — it does not change what the engine renders. If one engine
feeds several walls from a single output, see Crop NDI preview to this area under
Advanced mode.
No NDI output in Videowall mode
When a Viz Engine output is configured to run in Videowall mode, the engine's NDI output is disabled.
If you need an NDI feed of the wall, install NDI Tools on the videowall engine machine and enable its Screen Capture option.
Use this for setup only and disable it again before going into production — screen capture costs performance on the videowall engine machine.
The settings panel
Opened with the ... button in the VW Editor header, or from Settings → VW Editor tab. It
holds everything that is not a property of a single wall.
Videowall Editor
Setting
Meaning
Wall group
The videowall system every button on this tab acts on — Create Wall, Clear Scene and Build Room alike. The text next to it shows how many engines the selection resolves to, so an empty group is visible before you press anything. The extra all engines entry widens the actions to every videowall engine.
Show advanced actions
Reveals the advanced per-wall controls, see Advanced mode.
GFX channel
The GFX channel the wall panels project and the test room is loaded into. Walls pick up a change on the next Create Wall.
The headers of the two group boxes below name the active selection ("Walls — wall group 2"), so it
is always clear what a button is about to touch.
Walls
Button
What it does
Create Wall
Replaces the scene on the selected group's engine and rebuilds every wall of that group in it, then reads the scene tree back and reports which wall containers arrived.
Clear Scene
Replaces the scene on the selected group's engines with an empty one. The walls stay in the editor and can be rebuilt with Create Wall. Asks for confirmation.
The status line underneath reports per engine and names the scope, for example
"Group 2: 3 walls confirmed on 10.0.0.32:6100." A failure says why — engine not on air, no service
in the group, containers missing.
{warning}
Create Wall and Clear Scene replace the whole scene on that engine. Anything else built in it
by hand is lost. Moving a single wall between groups deliberately does not replace a scene.
{warning}
Test scene
The test scene is a grid room: a closed box around the studio origin, painted with a grid measured
from that origin, plus one grid panel per wall marking where each videowall sits inside it. It is
built as a scene of its own and loaded into the GFX channel the walls project — so you see it
through the walls. It is the quickest way to check that a wall's position, size and orientation in
the editor match the real panels.
Control
Meaning
Room W / H / D (cm)
Extent of the room. Width and depth are centred on the studio origin, the floor sits on the studio floor (Y = 0). 50 – 10000 cm.
Build Room
Builds the room on the selected group's engines. Each engine's room carries markers only for the walls of that engine's group.
Clear Room
Closes the room on every engine it is loaded on, whatever the group selection — so changing the selection cannot leave a room stranded.
Wall grids
Shows each wall's position as a coloured grid panel inside the room, in that wall's editor colour. Applies to a loaded room straight away.
Build without wall check
Builds the room even when the wall containers cannot be found on the engine — for wall scenes created by hand. The room is only visible through a wall's virtual window, so without one it may show nothing.
Advanced mode
Settings → VW Editor → Show advanced actions reveals the controls that are not needed for a
normal setup: the per-wall T and detect buttons in each wall header, and the UV Mapping
and Screen tabs in each wall's panel.
UV Mapping
Controls how the video content is mapped onto each panel of the wall — which part of the incoming
picture lands where. One block per panel:
Field
Meaning
Left / Right
Horizontal UV range of this panel, −2 … 2.
Top / Bottom
Vertical UV range of this panel, −2 … 2.
Rotation
Rotation of the mapping on this panel.
Lock UV mapping (keep manual values)
Stops Studio Manager from recalculating the UVs from the geometry, so hand-tuned values survive a change to the wall's dimensions.
By default the UVs are derived from the geometry — a One Corner wall splits the picture between its
two legs in proportion to their lengths. Edit them when the real content is laid out differently, and
tick Lock UV mapping to keep the edit.
The curved wall has no UV Mapping tab; its mapping follows the arc.
Screen
The Virtual Window screen attributes of the wall's top container — which part of the engine's
output the wall shows.
Field
Meaning
Position X / Y
Offset of the screen area, −100 … 100.
Dimension W / H
Size of the screen area, 0 … 100.
Applies the same crop to the NDI preview inside Studio Manager, stretched across the wall's geometry. For an engine that renders several walls, where its video out carries all of them.
Reset
Restores the defaults.
Target markers and corner detection
These two buttons support measuring a wall's real corners with the tracking system instead of typing
them:
  • T (Send Targets) — deploys the wall's target-marker scene to its engine. The wall then displays
    numbered markers on its corners, which the measurement/AI tool can detect from the camera image.
  • Detect — opens the target-assignment dialog, which assigns the detected corner positions to
    this wall and fills its corner coordinates.
The detected corners are read from targets.txt in the AI watch folder configured in the
settings (default C:\\ProgramData\\vizrt\\StudioManager\\Calibrationresults). Studio Manager watches
that folder, so the Detect buttons enable themselves as soon as enough targets are available. Each
wall type needs its own minimum:
Wall type
Targets needed
Back Wall
4
One Corner
6
Two Corner
8
Curved
5
Until that many targets are present, the button stays disabled and its tooltip says how many were
found. The result lands in the wall's corner mode coordinates, so it can be checked and corrected
by hand afterwards.
The target-assignment dialog opened for a wall,
showing the detected targets and the wall's corner slots they are assigned to.
Example setup
For a worked example — from an empty configuration to a wall on the engine — see
[Videowall Editor — Example Setup].
