Viz Trio User Guide
Version 4.0 | Published September 25, 2023 ©
Graphic Hub
To view the Graphic Hub configuration settings, click Graphic Hub in the Trio Configuration.
Graphic Hub Configuration Settings
These are the configuration settings to log on to Graphic Hub. All settings are local to the specific Viz Trio client.
Nameserver Host: Sets the hostname or IP address for the Viz DB server.
Graphic Hub URL: Sets the URL of the Graphic Hub REST service. If configured and running, Trio will use GH REST to fetch the thumbnails for the page- and playlists.
Database: Sets the name of the Graphic Hub database.
User Name: Sets the user name used for logging on to the database.
Password: Sets the password used for logging on to the database.
Auto Login: Enables Viz Trio to log on automatically at startup.
Note: If the local Viz Engine’s Auto Login is enabled, this option is disabled.
