Version 8.8 | Published September 25, 2023 ©
Object Store
Object Store is a tool to add, edit and search for still images (stills), person information and videos from a database. By letting you organize your own media library by adding custom meta data fields, Object Store also helps you customize your workflow, and helps you create your stories quickly and efficiently.
Note: Object Store was previously known as Viz Object Store, so the acronym VOS is still in use in some places.
Note: Object Store is not supported when using a Graphic Hub Database.
