Version 8.8 | Published September 25, 2023 ©
Newsroom Integration Installation
This installation type applies to a newsroom work station, where Viz Pilot News is integrated with one or more newsroom or NLE systems. The software is normally integrated to newsroom systems as an embedded component. This type of installation must be used when using Viz Pilot News together with Vizrt’s Graphics Plugin for NLE.
Note: When installing Viz Pilot News to use in a Java or web-based newsroom system, the Oracle Instant Client should not be installed.
Note: As most newsroom computers running it do not have administrator rights, you may need to install Viz Pilot News using RunAs parameters or install the software from the command line. You must have administrator rights for this to work.
Note: In order to use the NewsroomConnectTestPage on systems where Internet Explorer 11 is not available, copy the test page to a web server (such as the Pilot Data Server). Then configure Microsoft's Enterprise Site List to load this URL in IE8Enterprise mode. Use Microsoft Edge to visit the page on the new URL to load the Pilot News plugin.
The Viz Pilot newsroom installation includes the following Viz Pilot Components:
Viz Pilot News
Object Store
Documentation
Oracle Drivers
Local preview plugin
Spell check plugin
Quick CG
Note: The Local preview plugin can be removed if you prefer a setup that uses a remote Viz Engine for preview. The Oracle Drivers can also be removed if an instance of the Oracle Instant Client has already been installed.
