Configuration Files
The following configuration files are installed with the Viz Pilot system.
The default files are stored in the program folder with names in the format xxx.default.xxx.
Any changes are stored to files in %PROGRAMDATA%\Vizrt\Viz Pilot x.y\Config
File |
Use |
components.cfg |
Default Component Palette settings for Template Wizard |
custom_components.cfg |
Custom Component Palette settings for Template Wizard |
extra_components.cfg |
keyboard.kbd |
Keyboard Configuration for Director |
vtw_keyboard.kbd |
Keyboard Configuration for Template Wizard |
