Viz Multiplay User Guide
End-to-End Workflows
Basic Workflow
In the studio Viz Multiplay is used to create shows.
Operators use Viz Multiplay to manage the shows and trigger content for each screen.
Viz Engines composite graphics and video in real-time in SD/HD/4K SDI and IP streams.
In the studio, monitors and video walls are filled with the content controlled by Viz Multiplay.
Extended Workflow
Journalists create shows in Viz Trio or the newsroom control system.
In the control room, operators use Viz Multiplay to manage the shows, trigger content for each screen, and define content for the journalist in the studio to control.
The presenter in the studio controls screen content live with the Viz Multiplay touch-screen interface.
