This is a pre-release of Showmaker.
  • Showmaker can run standalone, as a rundown (running order) creation tool.
  • If you wish to use Showmaker with Viz Mosart, follow the instructions in section App Configuration.
Note: Whilst setup is relatively simple, the precise configuration depends on whether Showmaker is installed on the same server as Viz Mosart or a networked machine.
Operational Examples
This pre-release version of Showmaker is evolving rapidly. Already many tasks and workflows are fully functional.
Below is a starting point for finding some useful descriptions online:
Making your Rundown
Newsroom Tags for Pre-production Accuracy
Documentation Updates
As development evolves, the documentation is updated. Between software updates, it will be made available at the Vizrt Documentation Center.
