Viz Mosart User Guide
Version 5.6 | Published April 04, 2024 ©
Audio Countdown
Audio file directory: Tells Viz Mosart where to find the audio countdown files. Files must be in PCM WAV format (16 bit, 48 kHz).
File naming must adhere to a strict standard. As examples:-
60_sec.wav
30_sec.wav
10_sec.wav
5_4_3_2_1.wav
These are only examples. The Viz Mosart GUI countdown feature accepts and plays any file of the above format.
For example, a file named 30_sec can be played when 30 seconds remain of a given event. Similarly, a file named 5_4_3_2_1.wav will play at the 5 second mark. The voice on the wav could either count "5,4,3,2,1" or just announce "5", or what ever you require.
Note: For setting-up your Timing Display, see the section Timing Display.
Countdown to next BREAK template, file naming follows the standard of:
180_sec_Next_Break
120_sec_Next_Break
60_sec_Next_Break
30_sec_Next_Break
10_sec_Next_Break
5_4_3_2_1_Next_Break
Countdown story duration, file naming follows the standard of:
180_sec _End_Of_All_Stories
120_sec _End_Of_All_Stories
60_sec _End_Of_All_Stories
30_sec _End_Of_All_Stories
10_sec _End_Of_All_Stories
5_4_3_2_1 _End_Of_All_Stories
Countdown LIVE story duration, file naming follows the standard of:
180_sec _End_Of_Live_Story
120_sec _End_Of_Live_Story
60_sec _End_Of_Live_Story
30_sec _End_Of_Live_Story
10_sec _End_Of_Live_Story
5_4_3_2_1 _End_Of_Live_Story
Countdown FLOAT templates: Toggles an audio countdown file to be played from the Viz Mosart GUI PC when 3 minutes, 2 minutes, 1 minute, 30, 10 and 5 seconds remain until an adlibpix\float element with server\video content.
Countdown BREAK templates: Toggles an audio countdown file to be played from the Viz Mosart GUI PC when 3 minutes, 2 minutes, 1 minute, 30, 10 and 5 seconds remain until a designated Break line.
Countdown PACKAGE templates: Toggles an audio countdown file to be played from the Viz Mosart GUI PC when 3 minute, 2 minutes, 1 minute, 30, 10 and 5 seconds remain of the Package template.
Countdown story duration: Toggles an audio countdown file to be played from the Viz Mosart GUI PC when 3 minute, 2 minutes, 1 minute, 30, 10 and 5 seconds remain until the next story.
Count down to autostart rundown: Toggles an audio countdown file to be played from the Viz Mosart GUI PC when 3 minute, 2 minutes, 1 minute, 30, 10 and 5 seconds remain until the rundown will autostart.
Countdown LIVE story duration: Toggles an audio countdown file to be played from the Viz Mosart GUI PC when 1 minute, 30, 10 and 5 seconds remain until the editorial duration end of a live story.
Countdown to next BREAK template: Toggles an audio countdown file to be played from the Viz Mosart GUI PC when 3, 2 and 1 minute, as well as 30, 10 and 5 seconds remain until the next break.
Countdown VOICE OVER templates: Toggles an audio countdown file to be played from the Viz Mosart GUI PC when 1 minute, 30, 10 and 5 seconds remain of voiceover templates.
Offset countdown to next break: Defines an offset in seconds for the countdown to next Break feature.
Enable audio countdown: Plays audio when counting down.
