The main menu is located at the top of the Viz Mosart user interface, providing access to different functions and windows.
The various options in the main menu are briefly described below. Some more detailed explanations are provided later in this section.
Viz Mosart's primary source for rundowns is the NCS. Viz Mosart also saves the rundown (as an XML file) on the Viz Mosart server. Viz Mosart automatically saves changes to the rundown, but the user may also save manually. To distinguish later versions of a rundown from the original, Viz Mosart appends a timestamp to the file name of any subsequent version. The user may also open a rundown from one of these files. The file rundown is mainly meant for debugging purposes, and not intended for on air productions.
The Rundowns item contains the following options:
  • Open from file. Lists rundowns found in the folder mentioned above. Normally stored at C:\Manus.
    • Refresh. Refreshes the list of available rundowns.
      Between Refresh and Special there are eight menu options for 'today' (this and similar words not referring to the day of writing or the day of reading, but to the day of Viz Mosart use), yesterday, the day before yesterday, up to the day a week ago. The option names are the names of the days in the language of the user's computer. For each of these eight days, there is a sub-menu containing the timestamped rundown files saved on that day. (If none, there is no sub-menu.)
    • Special. Lists the non-timestamped rundown files.
  • Save as. Saves the current rundown with a new name in the window that opens.
Note: Do not include an underscore ('_') in the name. Files with underscore in the name will be automatically deleted once Manus expiration time has been reached. See the Viz Mosart Administrator Guide, section Manus Administrator Configuration
  • Save. Saves the current rundown.
 Note: By default, the location where rundowns are saved is C:\manus, but this may be overridden by the Manus Directory setting in the Settings Editor. Refer to the Viz Mosart Administrator Guide, section Manus Administrator Configuration.
  • Rehearsal. Enables rehearsal mode when selected. Click Rehearsal again to switch back to On Air mode. See Rehearsal and On Air Mode.
Note: Between Rehearsal and Arrange there may be additional options depending on the connected NRCS. For more information, see Managing NRCS Rundowns.
The View item contains the following options and sub-options:
  • Save as new workspace. Saves the current view/workspace with a new name in the window that opens.
  • Save workspace. Saves the current view/workspace.
  • Workspaces. Selects from the available workspaces.
  • Manage workspaces. Opens the Manage workspaces window.
  • Keyboard shortcuts. Determines which Keyboard Layout to be used.
  • Browse mode. Activates/deactivates Browse mode. For more information see Running Viz Mosart in browse mode. The appearance of this option is controlled in General Settings accessed from the Tools menu.
  • Floating windows. Lists both the different parts of the main window that can be released as separate windows, as well as windows that can be opened that are not part of the main window:
    Note: The 'eye' icon indicates a floated window.
    Releasing Windows
    Opening Windows
Provides a drop down list of the studio setups. Identical to 'Template Sets' in AV Automation in the Template Editor. See topic Show Design and Template Editor > Working with Template Sets in the Viz Mosart Administration Guide.
Provides a drop-down list of the graphics profiles. See the topic Overlay Graphics Configuration Property Tabs (under section Overlay Graphics Interface) in the Viz Mosart Administration Guide for more information.
Note: Selection here does not change the profile used for either Viz Mosart fullscreen or Overlay playlist graphics. The selection of this graphic profile only affects the PlaylistPanel GUI feature.
The drop-down list has two purposes:
  1. It lists the configured devices in AV Automation and Overlay Graphics Interface, with the current connection status.
    1. Green is connected and active.
    2. Red means not connected.
    3. Orange means in standby.
  2. Enables setting selected devices in and out of a standby state. Standby means the device is no longer under control of Viz Mosart; no commands will be sent to it from Mosart.
    During a production, this typically occurs when the device is no longer needed and can instead be used for other purposes (under manual control).
  • Standby state selection for a device is not changed if you switch to another GUI or switch to the backup Viz Mosart server.
  • Standby state selection will also be kept if you need to restart the Viz Mosart server while keeping the GUI running. This ensures that any such recovery actions will not interfere with the devices that are in standby, so that one does not risk that a Mosart problem impacts other devices than the ones that are currently under control by Mosart.
  • In AV Automation, it is possible to configure devices to be in standby at startup. See the Viz Mosart Administration Guide section AV Automation Device Properties > General, topic Standby at startup. In adherence of the above rule, these 'Standby at startup' selections are ignored if a Viz Mosart GUI is operational or if a backup Viz Mosart server is operational. Those settings thus only apply at a complete restart of all Viz Mosart applications.
Note: The naming of these menu-driven operations in the Overlay Graphics Interface and the Viz Mosart UI, are not the same.
Depending on the network setup, this item lists the main and backup server pairs configured in General Settings. The Status Bar updates when changing the connection.
The Tools item contains the following options:
  • General settings. Opens the General settings dialog. See General Settings.
  • Keyboard shortcuts editor.  Opens the Keyboard shortcuts editor. See Keyboard Shortcuts .
  • Keyboard shortcuts editor web.  Opens the new web-based shortcuts manager. See Keyboard Shortcuts .
  • Import shortcuts from server. See Keyboard Shortcuts Editor (section Exporting and Importing Shortcuts from Server).
  • Edit rundowns. Opens Edit Rundowns panel. See Managing NRCS Rundowns. This menu option only appears when having a connection to iNEWS. When using other newsrooms systems, the menu option is not visible.
  • Arrange rundowns. Opens the Arrange rundowns panel. See Arrange Rundowns.
  • Record. Opens a recording panel to create a new video recording. See Recording.
The Help item contains the following options:
  • License Configuration. Opens the License Configuration menu, intended for the Viz Mosart administrator. Please refer to the section Licensing in the Viz Mosart Administration Guide.
  • Viz Mosart User Guide. Opens (this) User Guide.
  • Viz Mosart Administrator Guide. Opens setup and configuration documentation intended for a Viz Mosart administrator.
  • About. Product version identifier and third party license details.
The Notifications icon to the right also appears at the top of all menus. A red marker indicates an unread notification.
  • Clicking the icon. Opens the Notification Box menu, listing important system messages that will usually require action.
