These config files are initially located in the Viz Mosart Server installation folder in a sub folder, Configuration Files.
For operations, you copy the file to "%ProgramData%/
Ardour Configuration File
This driver first reads the general configuration file named AudioMixerConfiguration.xml.
Then it reads the specific Ardour configuration file named AudioMixerArdour.xml.
Please see these files for the available settings and their documentation.
Calrec TCP/IP Configuration File
Then it reads the specific Calrec TCP/IP configuration file named AudioMixerCalrec.xml.
Info: AckTime and ConWait
The sample AudioMixerCalrec.xml file includes two settings AckTime and ConWait with their respective default values.
  • If you need to change the value of these defaults, you must at the same time, change the naming to all lowercase (acktime and conwait) for the change to be accepted and applied.
Lawo Ember+ Configuration File
Then it reads the specific Lawo Ember+ configuration file named AudioMixerLawoEmberPlus.xml.
MidiMixer Configuration File
Then it reads the specific MidiMixer configuration file named AudioMixerMidiMixer.xml.
Stagetec Configuration File
Then it reads the specific Stagetec configuration file named AudioMixerStagetecDiamondRas.xml.
Stagetec Ember+ Configuration File
This driver reads the Ember+ configuration file named AudioMixerEmberPlus.xml.
Please see that file for the available settings and their documentation.
Studer 3000 TCP/IP Configuration File
Then it reads the specific Studer 3000 TCP/IP configuration file named StuderOnAirEmberConfiguration.xml.
Studer Vista Configuration File
Then it reads the specific Studer Vista configuration file named StuderVistaEmberConfiguration.xml.
Tascam Sonicview 16 Ember+
General Audio Mixer Configuration File
Audio mixers not specifically mentioned above, all use the general configuration file named AudioMixerConfiguration.xml.
Info: In the default version of this file, there are some settings specific to the Lawo RMNOPL audio mixer driver.
