Gateway Administrator Guide
Version 5.5 | Published July 06, 2023 ©
Installation Test
This section describes how to test the installation of Gateway with Vizrt content control applications such as Viz Pilot and Viz Trio.
Content control applications usually do not edit playlists because a content control application is unable to update the NCS. Changes on the control station could cause undesired effects in the playlist when a story is updated from by newsroom system. However, Vizrt content control applications are capable of editing their own MOS Objects (also known as data elements) if needed.
