Gateway Administrator Guide
Version 5.5 | Published July 06, 2023 ©
Failover Settings
Failover Settings enable the user to manually configure a failover setup between two NCSs. This means that Viz Gateway routes messages to both NCSs. Whenever one or several new failover pairs are added or removed, the Gateway server must be restarted for the settings to take effect.
Note: Gateway’s failover setting is only supported by Associated Press’s Electronic News Production System (ENPS) and for a limited use case for the Sobey Newsroom System.
