The Page Editor allows editing of secondary events such as graphics and graphics with embedded video clips. The content for each page field can be manually set directly with a value using the Editor or dynamically set as described in Working with Page Content.
Info: Page Editor can only be opened when the local Viz Engine is successfully connected.
Header
The Page Editor modal displays key details about the opened Page in its header, including the context from which the Page was accessed, its name, and description. If the Page is added by reference, a note indicating this is also shown.
Page Editor: Name of the modal.
Page Pool: Location of the page, can also be “Playlist” or “Template Pool”.
Lower third (HD): Description of the page. If the description is empty, it will show “No description”.
(6000): Page name.
Editing Page by reference: Only displayed when the page is added by reference in a playlist.
Scene Preview Player
The Preview Player presents a representation of the graphics and video clips. In addition, it shows the defined title and safe area and the bounding boxes. Bounding boxes are related to the graphics scene's editable elements (see Page Fields List below).
Preview and timeline controls
The Preview Player includes timeline navigation controls, a slider and a time input, that allow you to move to any point in the preview. The slider can be updated by dragging or clicking at a desired position, while the time input can be adjusted by dragging, scrolling, typing, or using the arrow keys and increment/decrement buttons. These controls support the playback and navigation of graphics, including those with infinite loops.
There are also action buttons that allow controlling the timeline and preview area, as described below:
Icon | Description |
Continues or pauses the scene animation currently loaded if it contains any stop points. | |
Restarts the scene animation currently loaded in the local preview from the beginning. | |
Steps back approximately one frame, based on Frames per Second settings, see Channel Basic Info in section Basic Settings. | |
Steps forward approximately one frame, based on Frames per Second settings, see Channel Basic Info in section Basic Settings. | |
Shows or hides the Title Area in the Preview Player. | |
Shows or hides the Safe Area in the Preview Player. | |
Shows or hides the Bounding Box for the page field currently selected in the Preview Player. | |
Preview RGB version of the graphics with a default background color (black). Preview the Key version of the graphics. Preview the Graphics keyed on top of a still image (if configured in the Viz Engine). | |
Refresh the scene in the Preview Player. |
Page Fields List
The lower-left panel of the Page Editor presents available Page Fields (editable elements of the graphics) for the currently loaded Page or Template.
Click on a page field to display the available options.
Title: Name of the field.
Type: Field characteristic, like text, rich-text, image, video, clock, etc.
Content: The final content of the field.
Dynamic query: The Page Content Filling status.
Clicking the Trashcan icon will remove the Page Content Filling mapping done for this field. It is necessary to press Save afterwards to save the page.Query String: Shows the query string grabbing data from playlist metadata, or database query string.
Page Fields Editors
The panel on the right of the Page Editor presents various editors, corresponding to the type of the selected page field.
Text Editor
The Text Editor allows typing in the text input box. The content for the corresponding element of the graphics is updated.
Image Editor
The Image Editor presents three different browsers for selecting an image. The image path or URL is presented in the Image textbox when an image is set.
Graphic Hub Browser: Select an image from Graphic Hub. Graphic Hub needs to be configured in Global Settings first.
Viz One Browser: Select an image from Viz One. Viz One needs to be enabled in Global Settings first.
File Browser: Select an image from a local directory.
It is possible to adjust the position or scaling of an image, this adjustment can be verified in the Scene Preview Player. There are three options when adjusting scaling of an image:
Linked: x and y values update at the same time, with the same value.
Proportional: x and y values update at the same time, with their initial proportion.
Single: only x or y value are updated.
Video Editor
The Video Editor allows selecting a video from the Viz One browser. Viz One needs to be enabled in Global Settings first.
This is the only browser available for this editor.
Once a video is selected, Title and House Id can be verified in their text boxes that display below the image.
Clock Editor
The Clock Editor is used to create a timer. It is possible to set the start and halt time for the timer, or let the timer count indefinitely. The timer can be set to count up or count down.
Integer Editor
The Integer Editor allows typing an integer in the Value input box. The content for the corresponding element of the graphics is updated.
Float Editor
The Float Editor allows typing a float in the Value input box. The content for the corresponding element of the graphics is updated.
Control Container Editor
The Control Container Editor allows to control visibility, position, rotation, and scaling for a control object. The adjustments can be verified in the Scene Preview Player. This panel can be attached to any of the editors above or have its own field in the page fields list. When any dimension is not exposed from Viz Artist, it will be disabled in this view.
There are three options when adjusting the scaling of a control object:
Linked: x, y and z values update at the same time, with the same value.
Proportional: x, y and z values update at the same time, with their initial proportion.
Single: Only x or y or z value are updated.
General Actions
Clear all dynamic queries: Removes all Page Content Filling mapping done for each page field.
Note: Click Save after your actions, to save the page.
Cancel: Closes Page Editor without saving changes.
Save as: Saves all the changes to a new page. A pop up a dialog window is presented to submit a new page name.
This option is only available for Pages opened from the Template or Page Pool.Save: Saves all the changes in the current page. This button is only available for Pages opened from the Page Pool or from a Playlist.
