Scene Tree Shortcuts
General Shortcuts
Function |
Key and/or Mouse Shortcut |
Moves to Top Container |
HOME |
Moves to Last Container |
END |
Moves to top of page |
PAGE UP |
Moves to bottom of page |
PAGE DOWN |
Scrolls up the Container list |
ARROW UP |
Scrolls down the Container list |
ARROW DOWN |
Opens Container tree |
ARROW RIGHT |
Closes Container tree |
ARROW LEFT |
Open Plugin panel |
+ (plus) |
Basic View Controls and Shortcuts
Function |
Inserts New Container |
CTRL + INSERT (The new Container is created above the first selected Container.) |
Multiselects Containers |
CTRL + Right click |
Deletes selected Container(s) |
CTRL + DELETE |
Opens Tree |
CTRL + O |
Opens Subtree |
ALT + Click on expand icon |
Collapses Tree |
CTRL + I |
Collapses Subtree |
ALT + Click on collapse icon |
Locks selected Container(s) |
CTRL + L |
Unlocks selected Container(s) |
CTRL + SHIFT + L |
Groups selected Container(s) |
CTRL + G |
Ungroups selected Container(s) |
CTRL + SHIFT + G |
Hides selected Container(s) |
CTRL + H |
Shows selected Container(s) |
CTRL + SHIFT + H |
Searches Container |
CTRL + F |
Undoes action |
CTRL + Z |
Redoes action |
CTRL + Y |
Saves the Scene |
CTRL + S |
Copies selected Container(s) |
CTRL + Left click on container name and drag |
Copies selected Container(s) to Clipboard |
CTRL + C |
Pastes Containers from Clipboard |
CTRL + V (They are created one hierarchical level underneath selected container.) |
Cuts selected Container(s) |
CTRL + X |
Moves selected Container(s) |
Moves selected Container and retain transformation properties |
ALT + Left click on container name and drag |
Copies Properties of Container |
Left click on container Properties and drag |
Merges Group |
CTRL + M |
Splits Container |
CTRL + SHIFT + M |
Plug-in Overlay
Function |
Select plug-in |
Cursor Keys |
Select plug-in and apply to selected container(s) |
ENTER |
Leave plug-in Overlay |
ESC |
