Container and Scene Properties
This section details how to add Items and Built Ins to a Container, multiple Containers and Scenes.
Most properties can be dragged to a target Container, or Containers, in the Scene Tree (1), the Properties Panel (2) or the Scene Editor (3). Each property also has a context menu where a property can also be added to a Container, multiple Containers and Scenes.
This section containers the following procedures:
To Add Properties to an Empty Scene Tree
These properties can be added to an empty Scene Tree:
Items |
Built In |
Drag a property to either:
The Scene Tree (creates a new Container)
The Scene Editor (creates a new Container in the Scene Tree)
Tip: If multiple Geometry or Image items are dragged from the Item List to the Scene Tree, a Container for each selected item is created.
To Add Properties to a Container
These properties can be added to a Container:
Items |
Built In |
Only one Geometry plug-in, one Shader or one Media Asset can be applied to a single Container. If a new Geometry plug-in, Shader or Media Asset is added the first one is removed from the Container.
Tip: If a Shader, Media Asset or a few Container plug-ins are dragged to an object in the Scene Editor, they are added to the Container which contains the Object. The Media Asset is added as a Texture. If a Container plug-in can be added this way, the object becomes active when the Container plug-in is moved over the object.
Select a Container.
Right-click a property and select Add to Container(s). Media Assets give the option to Add <Media Asset> as DVE or as Texture.
Note: If no Container is selected the property is added to the top container in the Scene Tree.
or
Drag the property to a Container
Note: Media Assets are added as Texture to the Container.
Material items only:
Right-click a Container
Click on Add Material...
To Multi Drop Properties as Sub Containers
These properties can be multi dropped and create Sub Containers:
Items |
Built In |
Drag a selected property to the Scene Tree (aligned with a Container).
Hold the left-click and right-click to add the property to a new Sub-Container of the highlighted Container.
Keep the left-click and repeat as required.
Tip: Also works if multiple Geometries are selected.
Note: When the last property to be added has been dropped, release the right-click while the cursor is still aligned the target Container. If the right-click is released when over or aligned with another Container, another (not required) Container or Sub-Container, and Property is added.
Note: A Media Asset is added as a Texture.
To Multi Drop Properties on Containers
These properties can be multi dropped on Containers:
Items |
Built In |
Drag a property over a Container.
Tip: These properties can be dragged to the Scene Tree and aligned with a Container to add them: Materials, Materials Advanced, Container plug-ins and Shaders.
Hold the left-click, and right-click to add the property to the highlighted Container.
Note: When the last property to be added has been dropped, release the right-click while the cursor is still over the target Container. If the right-click is released when over or aligned with another Container, another (not required) Container or Sub-Container, and Property is added.
To Add Multiple Properties to Containers
These properties can be Multi Added to a Container:
Items |
Built In |
None |
Multi select the required properties.
Drag the selected properties to the Scene Tree or a Container:
In the Scene Tree (1(aligned with a Container)): All selected properties are placed in the Scene Tree as sub-containers of the highlighted Container, or
Over a Container (2). The first selected property is added to the highlighted Container and the other selected properties create new Containers, at the same level
To Add Properties to Multiple Containers
These properties can be added to Multiple Containers:
Items |
Built In |
Multi select the required Containers.
Add a property:
Right-click a property and select Add to Container(s),
or
Drag a property to one of the multi selected Containers.
To Add a Scene Plug-in to a Scene
Open the plug-in tab in Video Clip Playback Considerations:
Click on Scene Settings > plug-in, or
Click on the Scene plug-in icon (1)
Drag a Scene plug-in icon to the Scene drop area.
or
Right-click the Scene plug-in icon to open the plug-in Context Menu.
Click on Add to Scene...
If a Scene plug-in has been applied to a Scene, the Scene plug-in icon shows orange
