MCP Server Integration
Viz Arc includes an MCP (Model Context Protocol) server that enables integration with AI assistants and development tools. MCP is an open standard (now under the Linux Foundation) that provides a universal way to connect AI tools to external data and capabilities.
Compatible MCP Clients
The Viz Arc MCP server works with any MCP-compatible client, including:
Client
Type
Notes
Claude Desktop
Desktop App
Anthropic's desktop application
ChatGPT Desktop
Desktop App
OpenAI's desktop application (MCP support added March 2025)
Cursor
IDE
AI-powered code editor with MCP support
VS Code + Copilot
IDE
GitHub Copilot agent mode supports MCP
Windsurf
IDE
Built-in MCP Plugin Store
Cline
VS Code Extension
Autonomous coding agent with MCP integration
Continue
IDE Extension
Open-source extension for VS Code and JetBrains
OpenAI Codex
CLI/IDE
Supports MCP servers in CLI and IDE extension
Architecture Overview
MCP Client VizArc.McpServer.exe Viz Arc
(Any compatible) <----> (Lightweight server) <----> (Main application)
stdio REST API
Benefits
  • Work with multiple AI tools, not locked to one provider.
  • Use your existing AI subscriptions.
  • Access Viz Arc documentation and templates from your preferred tool.
  • Create and modify templates through natural conversation.
  • Work alongside the main Viz Arc application.
Setup Instructions
Step 1: Locate the MCP Server
Find VizArc.McpServer.exe in your Viz Arc installation:
C:\Program Files\Vizrt\Viz Arc\MCP\VizArc.McpServer.exe
Step 2: Configure Your MCP Client
Configuration varies by client. Below are examples for popular MCP clients.
Claude Desktop
  1. Open configuration file: %APPDATA%\Claude\claude_desktop_config.json.
  2. Add the configuration:
    "mcpServers": {
    "vizarc": {
    "command": "C:\\Program Files\\Vizrt\\Viz Arc\\MCP\\VizArc.McpServer.exe",
    "args": []
  3. Restart Claude Desktop completely (check system tray).
ChatGPT Desktop
  1. Open ChatGPT Desktop settings.
  2. Navigate to MCP Servers section.
  3. Add new server with command: C:\Program Files\Vizrt\Viz Arc\MCP\VizArc.McpServer.exe.
  4. Restart ChatGPT Desktop.
Cursor
  1. Open Cursor Settings (CTRL + ,).
  2. Navigate to MCP section.
  3. Add server configuration:
    "vizarc": {
    "args": []
  4. Restart Cursor.
VS Code with GitHub Copilot
  1. Open VS Code Settings (CTRL + ,).
  2. Search for MCP.
  3. Edit settings.json and add:
    "github.copilot.chat.mcpServers": {
    "vizarc": {
    "args": []
  4. Reload VS Code.
Windsurf
  1. Open Windsurf's MCP Plugin Store.
  2. Search for VizArc or add custom server.
  3. Set command path: C:\Program Files\Vizrt\Viz Arc\MCP\VizArc.McpServer.exe.
OpenAI Codex CLI
codex --mcp-server "C:\Program Files\Vizrt\Viz Arc\MCP\VizArc.McpServer.exe"
Important: Use double backslashes (\\) in JSON paths for Windows.
Step 3: Verify Connection
After configuring your MCP client:
  1. Start a new conversation.
  2. Ask: "What Viz Arc tools do you have access to?".
The AI should respond with information about available Viz Arc tools.
Example Prompts
For documentation queries (Viz Arc not required)
  • "Show me the available parameter types in Viz Arc"
  • "How do callbacks work in Viz Arc templates?"
  • "What is the difference between SetControlObject and UpdateTemplate?"
For live template work (Viz Arc must be running)
  • "What template do I have open in Viz Arc?"
  • "Add a text input parameter called 'headline' to my current template"
  • "Show me the control objects available in my template"
  • "Link the 'score' parameter to the 'ScoreText' control object"
Available AI Tools
The MCP server exposes its capabilities in three groups: static tools that work at any time, resources that provide documentation and reference material for the AI to read, and dynamic tools that operate on the running Viz Arc application. Dynamic tools require Viz Arc to be running with a valid AI license.
Static Tools (Always Available)
These tools work without Viz Arc running – they answer questions about scripting, parameters and best practices directly from the bundled documentation.
Tool
Description
start_template_generation
Entry point for creating a template: Returns the required JSON format and comprehensive guidelines, and points the assistant to the relevant documentation resources before it starts generating.
list_parameter_types
Lists all Viz Arc UI parameter types (button, text, slider, dropdown, toggle, table, and so on) with their properties, usage examples and best practices.
query_documentation
Searches the Viz Arc API documentation for specific topics, functions or concepts and returns the relevant sections.
Resources
In addition to tools, the MCP server publishes MCP resources (read-only reference documents that compatible AI clients can load as context). This replaces the former get_documentation, get_parameters_reference and get_sample_templates tools.
Resource
Description
Documentation
The complete Viz Arc scripting API reference: All functions, callbacks and global objects available in template scripts.
Parameters Reference
Comprehensive reference for all parameter types, including properties, methods and usage examples.
Sample Templates
Sample template implementations demonstrating best practices and common patterns.
Reference Templates
Complete, production-ready template examples with full JavaScript implementations.
Structured Samples
A library of template patterns in JSON format with metadata and keywords for easy discovery.
Template Schema
The JSON schema and structure guide for Viz Arc templates, including parameter definitions and the expected response format.
Dynamic Tools (Require Viz Arc Running)
Dynamic tools work on the live application – the project, the template currently open in the Template Designer, the scripts and the playlist.
Project and Templates
Tool
Description
get_current_project
Returns information about the loaded project: name, path, templates and configuration.
list_templates
Lists all templates in the current project with names, IDs, types and metadata.
get_template
Returns the details of a specific template, including its script code, parameters and configuration.
create_template
Creates a new template and opens it in the Template Designer for editing.
get_current_editing_template
Returns the template currently open in the Template Designer (the basis for the live-link workflow).
modify_current_template
Applies changes to the open template: script code, parameters to add/update/remove, and control object links (all in a single call).
validate_template_code
Validates JavaScript or VBScript template code for syntax errors and common issues.
Visual Verification
The assistant can check its own work visually and geometrically, iterating until the template layout is clean.
Tool
Description
get_template_snapshot
Captures a PNG screenshot of the template open in the Template Designer, exactly as the operator sees it at runtime.
analyze_template_layout
Analyzes the parameter layout without an image: Reports overlapping parameters, children sticking out of panels, misaligned columns and labels that may be clipped.
Control Object Linking
Tool
Description
get_control_objects
Returns all control objects of the open template with types, properties, linkage status and a suggested parameter type for each.
link_parameter_to_control_object
Creates a UI linkage between a parameter and a control object.
unlink_parameter
Removes the linkage from a parameter.
get_parameter_linkages
Lists all current linkages between parameters and control objects, both UI and code linkages.
is_control_object_linked
Checks whether a specific control object is linked to a parameter, and with which linkage type.
generate_set_control_object_code
Generates correct JavaScript code for SetControlObject to link a parameter value programmatically.
generate_update_template_code
Generates correct JavaScript code for UpdateTemplate to send control object values to the graphics engine.
Script Editing
Script tools that are aware of Viz Arc's current mode, plus direct access to the project's global script.
Tool
Description
get_current_editing_mode
Returns the current editing mode (Template Design, Global Script, Actions, On Air, …) so the assistant knows which context it is working in.
get_current_editing_script
Reads the currently editing script (automatically routes to the template or the global script depending on the current mode).
modify_current_script
Modifies the currently editing script (code and parameters), automatically routed by mode.
get_global_script
Reads the project-level global script, regardless of the current mode.
modify_global_script
Modifies the project-level global script, regardless of the current mode.
apply_script_from_file
Applies a script from a local UTF-8 file (the reliable way to transfer long, AI-generated scripts that would exceed inline tool-argument limits).
Playlist
The assistant can build and manage complete playlists. Describe the desired rundown and it assembles the playlist from your templates, ready for playout.
Tool
Description
get_template_fields
Returns the fillable fields of a template action (names, types, labels and current values) so generated payloads match the template exactly.
create_ai_playlist
Creates a playlist from AI-generated data: Each item becomes a playlist entry that applies its field values to the template when executed.
list_playlist
Lists all items in a playlist tab as a hierarchy with UUIDs, names, types, durations and payload data.
update_playlist_item_payload
Updates field values on an existing payload item; fields are merged with the existing payload data.
duplicate_playlist_item
Clones a playlist row or folder (with all children); the clone is inserted right after the original.
rename_playlist_item
Renames a folder or payload item label.
remove_playlist_item
Removes a playlist item or folder (with all children) by UUID.
clear_playlist
Removes all items from a folder or an entire playlist tab.
move_playlist_items
Moves one or more items into a folder or to the tab root, including cross-tab moves.
reorder_playlist_item
Changes an item's position within its current parent.
set_playlist_item_duration
Sets the duration of a playlist item; parent folder durations and the tab total are recalculated automatically.
  • "Take a snapshot of the template and fix any overlapping or misaligned parameters."
  • "Build a playlist for tonight's match from this fixture list, one lower third per player."
  • "Add a callback to the global script that writes every DataMap change to the log."
Modifying Parameters
When using modify_current_template, you can update various parameter properties:
Property
Description
x, y
Parameter position
width, height
Parameter dimensions
label
Display label
parameterColor / backgroundColor
Background color
Supported Color Formats
  • Hex: #FF5500 or #AARRGGBB
  • RGB function: RGB(255, 85, 0)
  • Comma-separated: 255, 85, 0
  • JSON object: {"R": 255, "G": 85, "B": 0}
Troubleshooting
AI Prompt Panel Not Visible
Cause: AI license not valid or not available.
Solution:
  1. Verify AI license status in System > Configuration > Info.
  2. Contact your Vizrt representative if license is missing.
MCP Server Not Connecting
Check 1: Configuration file syntax
  • Ensure claude_desktop_config.json has valid JSON syntax.
  • Verify double backslashes in Windows paths.
Check 2: Executable path
  • Confirm VizArc.McpServer.exe exists at the specified path.
  • Test by running the executable directly in a terminal.
Check 3: Restart Claude Desktop
  • Fully quit Claude Desktop (check system tray icon).
  • Relaunch the application.
"AI License Required" Error
Cause: Valid AI license not detected.
Solution:
  1. Ensure Viz Arc is running.
  2. Verify AI license in System > Configuration > Info.
  3. Contact your Vizrt representative for license issues.
Documentation Not Loading
Check that the documentation folder exists: %ProgramData%\Vizrt\VizArc\Resources\MCP\AI_Documentation\.
If missing, reinstall Viz Arc or contact support.
Dynamic Tools Not Working
Cause: Viz Arc application not running.
Solution:
  1. Start Viz Arc.
  2. Load a template in template editor.
  3. Try the tool again.
Note: Static tools (documentation, parameter types) work without Viz Arc running. Dynamic tools require Viz Arc to be running with a loaded template.
