Packages are the unit of installation in VAM. Everything you can add, configure, upgrade, or remove is a package.
The Packages View
The default landing page after sign-in lists every package known to the installation, grouped by category (Applications first). Each package is shown as a card.
Packages list
Across the top you have:
  • Search: filter the list by name.
  • Filter chips: All, Installed, Available, Healthy, Warning, Unhealthy (each with a count) to narrow what's shown.
  • Refresh catalog: re-pull the catalog from the registry so newly published packages / versions appear (no redeploy needed).
  • Export All and Show preview packages for advanced use.
Each card shows the package's name, installed version, a short description, its pod count (for example, 2/2 pods) and badges such as Update available. Infrastructure/system packages are hidden by default — use Show all packages to reveal them.
Click a card to open the package detail view.
Package Detail View
The package detail view is where you do everything for a single package. Lifecycle actions live in the button row at the top — Upgrade, Restart, Stop, Scale and an overflow menu (Uninstall lives here when the package allows it). Below that is a set of tabs:
  • Overview: status (health, installed version, chart/app version, pod readiness), access URLs, the package's enabled features, release notes (the "What's new" changelog), its dependencies and a visual dependency graph.
  • Pods: the package's running pods and their status.
  • Config: the package's settings, as a form generated from the package's published config schema (schema-validated).
  • Logs: recent log output from the package's pods.
  • Secrets: the secrets the package consumes (values are never shown).
  • Diagnostics: additional detail for support/debugging.
Installing a New Package
  1. On the Packages view, filter by Available (or use Refresh catalog first if you just published something).
  2. Click the package card to open its detail view.
  3. Read the description and check the Dependencies section / dependency graph. Any missing required dependencies are listed; the UI installs them in the right order if you accept.
  4. Click Install.
  5. Fill in the configuration form. Required fields are marked; the form does not let you submit until they are filled and valid. Some packages add gates here (for example a GPU check).
  6. Click Install to start.
  7. Live progress is shown step-by-step. On success, the package appears as Installed with status Healthy.
If the install fails, expand the failed step to read the diagnosis. Most failures are configuration problems — fix the values, then retry from the package detail page.
Configuring an Installed Package
  1. Open the package's detail view.
  2. Click the Config tab.
  3. Edit values. As you change a field, the UI validates against the package's schema and shows inline errors if a value is out of range, the wrong type, etc.
  4. Save:
    • Save Configuration persists the values without redeploying.
    • Save & Apply persists and rolls the change out to the running package.
    • Reset to Saved discards your unsaved edits.
  5. Disruptive changes are applied in place — typically with no downtime.
Some configuration values (database passwords, OIDC client secrets) are sealed secrets; the UI shows •••••••• for the current value and lets you replace it, never read it back.
Upgrading a Package
  1. The package card / detail page shows an Update available badge when the catalog has a newer version. (Use Refresh catalog to pick up newly published versions.)
  2. Click Update.
  3. A dialog shows what's changing — vX → vY: the release notes / changelog for the new version and the configuration to review.
  4. Click Update to start; live step-by-step progress is shown.
If an upgrade fails, it is automatically rolled back to the last known-good version and the dialog explains what happened — so a bad upgrade does not leave the package broken.
Self-upgrade: the Configuration Service can upgrade itself through this same flow. When it does, it briefly restarts and reconnects automatically and a dedicated progress dialog tracks the steps. Upgrading the core VAM platform (and adding/removing cluster nodes) is still done through the vamctl installer.
Uninstalling a Package
  2. Click Uninstall.
  3. Read the warning — uninstalling deletes the package's data.
  4. Type the package name to confirm.
  5. Click Uninstall.
If other installed packages depend on this one, the UI refuses and lists the dependents. Uninstall them first (or, if intentional, override with Force uninstall — but only after reading the warning).
Reading Package Logs
Open the Logs tab on the package detail view. The UI streams recent log lines from the package's pods. Filter by:
  • Severity: show only errors / warnings / info / debug.
  • Pod: if the package has multiple pods, pick one.
  • Time range: last 5 minutes / 1 hour / 24 hours / custom.
For long-term log analysis (beyond what the UI buffer holds), contact your administrator about the cluster's observability stack.
