Tracking Hub
Version 1.2 | Published December 12, 2018 ©
Viz Virtual Studio Folders
Installation Folders
The default installations folders are:
         Windows System  |
         Viz Virtual Studio Platform  |
         Installation Folder  |
         Windows 7 32-bit  |
         32-bit  |
         C:\Program Files\vizrt\VizTHC:\Program Files\vizrt\Studio Manager  |
         64-bit  |
         N/A  |
         Windows 7 64-bit  |
         32-bit  |
         C:\Program Files (x86)\vizrt\VizTHC:\Program Files (x86)\vizrt\Studio Manager  |
         64-bit  |
         C:\Program Files\vizrt\VizTHC:\Program Files (x86)\vizrt\Studio Manager  |
Data Folders
Files which are created or can be modified are located in %ProgramData%\vizrt\VizTH, and include:
Config files.
Crash dump files.
Temporary files are located at: %TMP%\vizrt\viz3, which usually resolves to C:\Users\<user name>\AppData\Local\Temp\vizrt\Viz3. This folder is referenced as <viz temp folder> throughout this User Guide.
