Tracking Hub
Version 1.1 | Published December 03, 2018 ©
Viz Virtual Studio Folders
Installation Folders
The default installations folders are:
Windows System |
Viz Virtual Studio Platform |
Installation Folder |
Windows 7 32-bit |
32-bit |
C:\Program Files\vizrt\VizTHC:\Program Files\vizrt\Studio Manager |
64-bit |
N/A |
Windows 7 64-bit |
32-bit |
C:\Program Files (x86)\vizrt\VizTHC:\Program Files (x86)\vizrt\Studio Manager |
64-bit |
C:\Program Files\vizrt\VizTHC:\Program Files (x86)\vizrt\Studio Manager |
Data Folders
Files which are created or can be modified are located in %ProgramData%\vizrt\VizTH, and include:
Config files
Crash dump files
Temporary files are located at: %TMP%\vizrt\viz3, which usually resolves to C:\Users\<user name>\AppData\Local\Temp\vizrt\Viz3. This folder is referenced as <viz temp folder> throughout this User Guide.
