Tracking Hub
Version 1.1 | Published December 03, 2018 ©
Important Checklist Before Installation
The items listed below must be checked before an installation can be done on site. Before an installation can be started make sure:
Camera adjustments/shifts should always be set by camera personnel before any lens calibration is done. After any adjustments/shifts are set, the camera cannot be adjusted without being reconfigured.
Cables: Who is in charge of the cabling before doing an installation?
Tracking: What are the tracking system protocols?
Transfer of tracking data: How is tracking data transferred and what kind of cables are used?
Synchronization sources: What type of synchronization sources used?
Blackburst
Tri-level
Digital input 1&2 using SDI in
Location of the Viz Engines: Do you have physical access to the machines?
Coordinate system: What are the coordinate systems for the tracking system(s) used?
Make sure that there are no firewalls
System Requirements
This section detail the system requirements.
Syncronization
The Tracking Hub needs some sort of synchronization method on the machine it is installed. This can be:
a running Viz Engine installation, or
an installed Plura synchronization card.
If sync sources is not found, the Tracking Hub can still be used in “free running” mode. Free running is not intended and should not be used for production. It can, however, be used to experiment with tracking on a laptop. For use in production either Viz Engine or Plura synchronization is needed.
Minimum Hardware Configuration
Minimum 4 GB Ram
Dual-Core Intel or AMD CPU
Minimum 10 gigabytes of free disk space
Recommended Hardware and Software Configuration
8 GB Ram
Quad-Core Intel or AMD CPU
Windows 10 64-Bit
Supported Hardware and Software
Windows 7 32-Bit and 64-Bit
Windows 10 64-Bit
Viz Engine 3.9.0 (either 32-Bit or 64-Bit) or later
Plura PCL-PCI and PCL-PCIe (L, LV, 3G) timecode reader cards (Driver 5.36)
Studio Manager requires .NET framework 4.5.1 or higher.
