![](assets/images/logos/TemplateBuilder.png)
Template Builder User Guide
Version 2.3 | Published April 11, 2022 ©
Introduction
Template Builder lets you make customized templates using scene import or existing templates from Viz Pilot's Template Wizard. This user guide shows you how to customize templates.
Info: A key feature is that you can add custom HTML panels to templates, giving full control over the template through custom scripting and logic.
Workflow
A simplified version of the workflow follows below:
Scenes are made in Viz Artist.
The scenes are imported into Template Wizard, where templates are made.
Templates are edited and new templates can be made in Template Builder.
The template is saved in the Viz Pilot system and is available to newsroom and control room systems for playout.
Note: Changes made to a template in Template Builder are not be available when opening the template in Template Wizard.
Related Documents
The templates customized in Template Builder can be used by other Vizrt products such as Viz Pilot Edge, Viz Story and Viz Multiplay. For more information about all Vizrt products, visit:
Feedback
We welcome your feedback and suggestions regarding Vizrt products and this documentation. Please contact your local Vizrt customer support team at http://www.vizrt.com.
Legal
Copyright © 2022 Vizrt. All rights reserved.
Disclaimer
Technical Support
For technical support and the latest news of upgrades, documentation, and related products, visit the Vizrt web site at www.vizrt.com.
