General
Windows 10 (64-bit only)
Windows Server 2012 R2
Microsoft .NET 8 (Desktop Runtime and ASP.NET Core Runtime)
CodeMeter version 6.80 and later
Vizrt Software
Viz Engine version 4.4.0 and later.
Viz Arc version 3.0.0 and later.
Minimum Hardware Requirements
720p, 1080i, 1080p
Object Tracker
1x HP Z8 or Dell R7920
2x RTX 4000 or better
1x Matrox DSXLE4 or better
Viz Arc
HP Zbook Mobile Workstation
OR
1x HP Z4
1x RTX 2000
Information: Viz Arc must run on separate Hardware than the Object Tracker.
SDI Preview
If there is a requirement for an SDI Preview in addition to the SDI PGM OUT, an additional Object tracker box is required.
Antivirus
Antivirus Considerations
Real-Time Scanning: Keep it enabled, but exclude any performance-sensitive operations involving Vizrt-specific folders, files, and processes. For example:
C:\Program Files\[Product Name]
C:\ProgramData\[Product Name]
Any custom directory where [Product Name] stores data, and any specific process related to [Product Name].
Risk Acknowledgment: Excluding certain folders/processes may improve performance, but also create an attack vector.
Scan Scheduling: Run full system scans during off-peak hours.
False Positives: If behavior-based detection flags a false positive, mark that executable as a trusted application.
