Viz Arc User Guide
Version 2.0 | Published July 03, 2024 ©
Introduction
Viz Arc integrates to Viz Engine and scenes allowing you to design your virtual studios and augmented reality elements in Viz Artist, eliminating the need for creating custom applications to control virtual studios and augmented reality elements for each production.
-     A simple user interface allows you to create projects for each production.
-     Easily configure action buttons that control any property, element or animation in a Vizrt Scene without any programming or expert skills. Operators can access a panel of actions that can be triggered at any time.
-     Arc is an out-of-the-box solution that eliminates the need to create custom controllers for operating AR/VR elements and non-scripted shows.
-     Viz Arc lets you easily configure the logic of each individual element and operate virtual studios and augmented reality or graphic elements on a non-scripted live production, while reducing the setup time and expertise required.
Related Documents
-     Viz Artist User Guide: Contains information on how to install Viz Engine and create graphics scenes in Viz Artist.
-     Viz Engine Administrator Guide: Contains information on how to install and configure Viz Artist and Engine, and supported hardware.
-     Viz Graphic Hub Administrator Guide: Contains information needed to configure and operate Graphic Hub.
-     Viz Tracking Hub Administrator Guide: Contains information required to understand Tracking Hub and Studio Manager, two important software components in the Viz Virtual Studio solution.
-     Viz Pilot User Guide: Contains information needed to operate Viz Pilot and use the Newsroom Component to create newsroom data elements for a newsroom system playlist.
Feedback and Suggestions
We encourage feedback on our products and documentation. Please contact your local Vizrt customer support team at www.vizrt.com.
Legal
Copyright © 2024 Vizrt. All rights reserved.
Disclaimer
Antivirus
Vizrt does not recommend or test antivirus systems in combination with Vizrt products, as the use of such systems can potentially lead to performance losses. The decision for the use of antivirus software and thus the risk of impairments of the system is solely at the customer's own risk.
There are general best-practice solutions, these include setting the antivirus software to not scan the systems during operating hours and that the Vizrt components, as well as drives on which clips and data are stored, are excluded from their scans (as previously stated, these measures cannot be guaranteed).
Technical Support
For technical support and the latest news of upgrades, documentation, and related products, visit the Vizrt web site at www.vizrt.com.
