Viz Arc User Guide
Version 1.7 | Published November 15, 2022 ©
Viz Arena
Configuration
First of all you have to to enable the Viz Arena panel:
  • Go to the Viz Arc Configuration.
    images/download/attachments/95407816/00_Settings-1.PNG
  • Select the Vizrt System tab and press Enabled on Viz Arena.
    images/download/attachments/95407816/00_Settings.PNG
  • Insert the correct IP address of the workstation where Viz Arena resides and the port of the API server.
The Viz Arena status icon is located in the status bar (on the bottom right).
images/download/thumbnails/95407816/00_Settings-2.PNG
It turns green after a while if the IP address and port inserted are correct, otherwise it remains red.
Now it is available to press the Arena button on the "Tool toolbar" (on the leftmost portion of the window), the interface looks similar to this:
images/download/attachments/95407816/01_FullImage-0.PNG
Features
The Arena tab presents multiple features:
  • Actions panel (1), see Actions View for further information
  • Script panel (2), see Script View for further information
  • Output view panel (3)
  • Settings panel (4)
images/download/attachments/95407816/01_FullImage-1.png
Output View
The Output View shows the NDI stream, both video and metadata, provided by Viz Arena. Since it is very important to see any changes of the calibration status, at the very top of the view there is line that show its current value:
  • Green if the calibration is good.
  • Red if the calibration is lost.
Actions
Object Position
This action enables to position any selected control object (in the Action Panel) on the field (see image above). As a visual aid, the cursor turns into a cross when over the output view.
Mask Edit
This action enables to adjust the color model used for calibration and by the Viz Engine for keying during a live game. Add brush strokes to improve the classification of the foreground and the background to refine the color model.
images/download/attachments/95407816/06_Stroke.PNG
This action also turns on the visualization of the mask:
  • Color mask
images/download/attachments/95407816/02_FullImage-Mask.PNG images/download/attachments/95407816/04_FullImage-MaskColors.PNG
  • Black and white mask
images/download/attachments/95407816/03_FullImage-MaskBW.PNG
It is possible to toggle between the two modes see Settings panel > Mask > Back and White . During a live game, it is advised to regularly observe the output of the keying mask to ensure that the graphics are well rendered on Viz Engine and to provide the best possible tracking quality.
NDI Info
This button adds a new floating Info Panel to the interface.
images/download/thumbnails/95407816/06_NDIInfoPanel-1.PNG
  • Click on the gear images/download/thumbnails/95407816/06_NDIInfoPanel-2.PNG and the panel expands showing all the information that can be visualized:
images/download/thumbnails/95407816/06_NDIInfoPanel.PNG
Click again on the gear images/download/thumbnails/95407816/06_NDIInfoPanel-2.PNG to exit from configuration mode.
  • Click on the images/download/thumbnails/95407816/06_NDIInfoPanel-4.PNG to close the panel.
  • Grab the header to move the panel around and place it anywhere.
There is no limit to the number of panels that can be added.
Settings Panel
Calibrations
images/download/attachments/95407816/07_settings-1.png
  • Select a Camera/Calibration for both preview and program feed by clicking on the calibration name.
  • Detect Calibration [D]: Detects the calibration of the current image. Click this button (or press the D button) if the tracked calibration is off from the actual field lines.
Keying Presets
images/download/attachments/95407816/07_settings-2.png
  • Select a preset for preview feed by clicking on the preset name.
  • The preset that is currently On Air is marked with a red images/download/thumbnails/95407816/08_onair-1.png label.
  • If the On Air preset has any local changes that have not yet been applied to the output rendering, they are marked with an orange exclamation mark images/download/thumbnails/95407816/image2018-8-17_12-12-51.png .
  • Press images/download/thumbnails/95407816/08_onair.png to update the output rendering.
  • Press images/download/thumbnails/95407816/09_trash.png to remove the selected preset from the list. If it is the preset On Air, the button does nothing.
  • Press images/download/thumbnails/95407816/10_addpreset.png to add a new empty keying preset to the list. The name is the one inserted in the text box next to the button.
Mask
images/download/attachments/95407816/07_settings-3.png
  • Black and White: Toggles the style of the keying mask.
  • Mask Color: Selects the background keying mask color used for rendering which is most suitable for the playing field. Click on the colored rectangle and a new panel appears. Here it is possible to choose the mask color.
images/download/thumbnails/95407816/05_CustomColor.PNG
  • Background 1: Interacts with the background color model of the preset. Right click on the button and the color panel shows (see above), this changes the color of the stroke.
  • Background 2: Interacts with the background logo color model of the preset. Right click on the button and the color panel shows (see above), this changes the color of the stroke.
  • Foreground 1: Interacts with the foreground color model of the preset. Right click on the button and the color panel shows (see above), this changes the color of the stroke.
Controls
images/download/attachments/95407816/07_settings-4.png
  • For a better understanding of each control please refer to the Viz Arena User Guide.
  • Going over images/download/thumbnails/95407816/09_info.png with the mouse provides a brief description of the relative control.
  • Clear Color Model [C]: Clears the stored keying information about the current preset and starts updating the color model from scratch. Alternatively, use the shortcut C on the keyboard.
Startup
Using the command line parameter --a or --arena, it is possible to start Viz Arc directly with the Viz Arena tool visible.
