Viz Arc User Guide
Version 1.7 | Published November 15, 2022 ©
Installing Viz Arc
  1. Uninstall any previously installed Viz Arc versions.
  2. Run the installer. Depending on the target system, you might need to install the required prerequisites.
    images/download/attachments/105088868/installmain.png
    The Windows Desktop runtime and Asp.Net Core runtime get installed silently when they are missing on the target machine
    Select the parts you want to install on the target machine:
    1. Viz Arc, the main application.
    2. Viz Arc Web Service, required when Viz Arc actions shall be called from Viz Content Pilot.
    3. Viz Unreal Loader, required on machines running an Unreal Engine which are controlled by Viz Arc. This installer contains the Viz Arc communication plugins for the Unreal Engine which can be found
      in C:\ProgramData\vizrt\VizArc\Resources\unreal after installation.
  3. Press Finish to complete installation.
    images/download/attachments/105088868/installcomplete.png
Note: After installation, you must first configure your system, and request and apply the license to use all of the software features.
