Configuration Panel
The Configuration Panel is used to save and load Studio configuration profiles, select modes of operation including frequency, and to set some user interface options.
graphics/setup_studio_menu.png
Menu options:
  • Open: Open a Tracking Hub configuration file. The name of the currently loaded configuration file will always be displayed in the top bar, between the application’s name and main menu.
  • Save: Save the current Studio configuration.
  • Save As: Save the current Studio configuration with a new name.
  • Reset: Reset the current Studio configuration. Note that the loaded configuration file is only changed if save is clicked after resetting the configuration.
  • View Log: Open or close the Log Panel.
  • View Timing Analysis: Open the Timing Analysis Window.
  • Frequency: Select the production frequency; 50 Hz, 60 Hz or 59.94 Hz.
  • Synchronization Mode: Select synchronization mode for the Tracking Hub:
    • Freerun: No synchronization. The Tracking Hub uses its own time base, corresponding with the configured frequency.
    • AV-Card: Synchronization is done by an installed Plura card.
    • Viz Engine: Synchronized with Viz Engine, running on the same computer.
    Tip: If the selected synchronization mode is followed by a red box with a white horizontal line, this indicates synchronization issues.
