The Channel Recorder supports the following containers and codecs.
Note: If a combination of CODEC / CONTAINER / RESOLUTION is not supported, Channel Recorder floods the logs with errors. If this happens stop the recording using RECORD STOP
. Please make sure that the mentioned combination are supported by consulting the tables below.
Note: Only the containers AVCINTRAMXF, DVCPROMXF, XDCAMMXF, XAVCMXF support capturing of closed captions. The closed captions must be part of SMPTE 334M CDP. The captured close caption is found in the recorded clip in the wrapper according to SMPTE 436M and in the actual MXF essence.
Note: The examples below are not exhaustive. Some parameters such as the number of audio channels have other options.
PAL Codecs
MPEG-IFrame
Container | Codec | Features | Audio | VizSend Example | MVCP Example |
.avi | MPEG2-IFrame422 720x576 | Alpha: No | No Audio PCM:
| Specifying this codec / container combination is not supported through MVCP. If this codec / container combination is required then the web interface can be used to configure Channel Recorder. When sending MVCP commands, however, the codec / container must not be specified via vtr.media.video.input.compression.type. |
DVCAM
.avi | DV/DVCAM 4:2:0 720x576 | Alpha: No | No Audio PCM:
.mov | DVCAM 4:2:0 720x576 | Alpha: No | No Audio PCM:
.mxf | DVCAM 4:2:0 720x576 | Alpha: No | No Audio |
Information: Video bitrate is 25, but the encoded bitrate is 28.75 (15% more) which includes other data.
DVCPRO
.avi | DVCPRO 4:1:1 | Alpha: No | No Audio PCM:
.avi | DVCPRO 50 4:2:2 | Alpha: No | No Audio PCM:
.mov | DVCPRO 4:1:1 | Alpha: No | No Audio PCM:
.mov | DVCPRO 50 4:2:2 | Alpha: No | No Audio PCM:
.mxf (OP1a) | DVCPRO 4:1:1 | Alpha: No | PCM:
| UADD CS_ENCODER1 * SHAR dart SET U1 MED vtr.media.video.input.compression.type "dvcpro" SET U1 MED vtr.media.mpeg.bit_rate "25000000" SET U1 MED vtr.media.audio.input.channels "8" CUER U1 REC U1 |
.mxf (OP1a) | DVCPRO 50 4:2:2 | Alpha: No | PCM:
| UADD CS_ENCODER1 * SHAR dart SET U1 MED vtr.media.video.input.compression.type "dvcpro" SET U1 MED vtr.media.mpeg.bit_rate "50000000" SET U1 MED vtr.media.audio.input.channels "8" CUER U1 REC U1 |
.mxf Panasonic P2 (OP-Atom) | DVCPRO 4:1:1 | Alpha: No | No Audio |
| Specifying this codec / container combination is not supported through MVCP. If this codec / container combination is required then the web interface can be used to configure Channel Recorder. When sending MVCP commands, however, the codec / container must not be specified via vtr.media.video.input.compression.type |
.mxf Panasonic P2 (OP-Atom) | DVCPRO 50 4:2:2 | Alpha: No | No Audio |
Information: Video bitrate is 25, but the encoded bitrate is 28.75 (15% more) which includes other data. The same applies for 50 bitrate. The encoded bitrate is 57.6 (15% more).
XDCAM
.mxf XDCAM (OP1a) | D10 (IMX50) 4:2:2 | Alpha: No | AES3:
| UADD CS_ENCODER1 * SHAR dart SET U1 MED vtr.media.video.input.compression.type "mpeg2" SET U1 MED vtr.media.mpeg.bit_rate "50000000" SET U1 MED vtr.media.audio.input.channels "4" CUER U1 REC U1 |
.mxf XDCAM (OP1a) | D10 (IMX40) 4:2:2 | Alpha: No | AES3:
| UADD CS_ENCODER1 * SHAR dart SET U1 MED vtr.media.video.input.compression.type "mpeg2" SET U1 MED vtr.media.mpeg.bit_rate "40000000" SET U1 MED vtr.media.audio.input.channels "4" CUER U1 REC U1 |
.mxf XDCAM (OP1a) | D10 (IMX30) 4:2:2 | Alpha: No | AES3:
| UADD CS_ENCODER1 * SHAR dart SET U1 MED vtr.media.video.input.compression.type "mpeg2" SET U1 MED vtr.media.mpeg.bit_rate "30000000" SET U1 MED vtr.media.audio.input.channels "4" CUER U1 REC U1 |
NTSC Codecs
MPEG IFrame
.avi | MPEG2-IFrame422 720x480 | Alpha: No | No Audio PCM:
DVCAM
.avi | DV/DVCAM 4:1:1 720x480 | Alpha: No | No Audio PCM:
.mov | DVCAM 4:1:1 720x480 | Alpha: No | No Audio PCM:
.mxf Panasonic P2 (OP-Atom) | DVCAM 4:1:1 720x480 | Alpha: No | No Audio |
DVCPRO
.avi | DVCPRO 4:1:1 720x480 | Alpha: No | No Audio PCM:
.avi | DVCPRO 50 4:2:2 720x480 | Alpha: No | No Audio PCM:
.mov | DVCPRO 4:1:1 720x480 | Alpha: No | No Audio PCM:
.mov | DVCPRO 50 4:2:2 720x480 | Alpha: No | No Audio PCM:
.mxf (OP1a) | DVCPRO 4:1:1 720x480 | Alpha: No | PCM:
.mxf (OP1a) | DVCPRO 50 4:2:2 720x480 | Alpha: No | PCM:
.mxf Panasonic P2 (OP-Atom) | DVCPRO 4:1:1 720x480 | Alpha: No | No Audio |
.mxf Panasonic P2 (OP-Atom) | DVCPRO 50 4:2:2 720x480 | Alpha: No | No Audio |
XDCAM
.mxf XDCAM (OP1a) | D10 (IMX50) 4:2:2 720x512 | Alpha: No | AES3:
.mxf XDCAM (OP1a) | D10 (IMX40) 4:2:2 720x512 | Alpha: No | AES3:
.mxf XDCAM (OP1a) | D10 (IMX30) 4:2:2 720x512 | Alpha: No | AES3:
720p50 and 720p59.94 (60M) Codecs
MPEG-IFrame
.avi | MPEG2-IFrame422 1280x720 | Alpha: No | No Audio PCM:
DVCPRO HD
.avi | DVCPRO HD 1280x720 | Alpha: No | No Audio PCM:
.mov | DVCPRO HD 960x720 | Alpha: No | No Audio PCM:
.mxf (OP1a) | DVCPRO HD 960x720 | Alpha: No | PCM:
| UADD CS_ENCODER1 * SHAR dart SET U1 MED vtr.media.video.input.compression.type "dvcpro" SET U1 MED vtr.media.audio.input.channels "8" CUER U1 REC U1 |
.mxf Panasonic P2 (OP-Atom) | DVCPRO HD 960x720 | Alpha: No | No Audio |
XDCAM HD 422
.mxf (OP1a) | XDCAM HD 422 1280x720 | Alpha: No | No Audio PCM:
| UADD CS_ENCODER1 * SHAR dart SET U1 MED vtr.media.video.input.compression.type "mpeg2-ibp-422p@hl" SET U1 MED vtr.media.audio.input.channels "8" CUER U1 REC U1 |
XDCAM EX HQ
.mxf (OP1a) | XDCAM EX HQ 1280x720 | Alpha: No | No Audio PCM:
AVC-Intra
.mxf (OP1a) | AVCIntra Class 50 960x720 | Alpha: No | PCM:
| UADD CS_ENCODER1 * SHAR dart SET U1 MED vtr.media.video.input.compression.type "avc-intra" SET U1 MED vtr.media.mpeg.bit_rate "50000000" SET U1 MED vtr.media.audio.input.channels "8" CUER U1 REC U1 |
.mxf (OP1a) | AVCIntra Class 100 1280x720 | Alpha: No | PCM:
| UADD CS_ENCODER1 * SHAR dart SET U1 MED vtr.media.video.input.compression.type "avc-intra" SET U1 MED vtr.media.mpeg.bit_rate "100000000" SET U1 MED vtr.media.audio.input.channels "8" CUER U1 REC U1 |
.mxf Panasonic P2 (OP-Atom) | AVCIntra Class 50 960x720 | Alpha: No | No Audio |
.mxf Panasonic P2 (OP-Atom) | AVCIntra Class 100 1280x720 | Alpha: No | No Audio |
ProRes
.mov | I-Frame 4:2:2 1280x720 | Alpha: No | No Audio PCM:
DNxHD
.mxf (OP1a) | DNxHD (50) 120, 175 DNxHD (59.94) 145, 220 1280x720 | Alpha: No | No Audio PCM:
.mxf (OP1a) | DNxHD (50) 175x DNxHD (59.94) 220x 1280x720 | Alpha: No | No Audio PCM:
.mxf Panasonic P2 (OP-Atom) | DNxHD (50) 120, 175 DNxHD (59.94) 145, 220 1280x720 | Alpha: No | No Audio |
.mxf Panasonic P2 (OP-Atom) | DNxHD (50) 175x DNxHD (59.94) 220x 1280x720 | Alpha: No | No Audio |
XAVC
.mxf (OP1a) | XAVC | Alpha: No | PCM:
.mxf (OP1a) | XAVC Long GOP | Alpha: No | PCM:
Note: The configuration v210 must be enabled in the configuration section for recording XAVC.
1080i25 and 1080i29.97 (30M) Codecs
MPEG-IFrame
.avi | MPEG2-IFrame422 1920x1080 | Alpha: No | No Audio PCM:
DVCPRO HD
.avi | DVCPRO HD (25) 1920x1080 DVCPRO HD (29.97) 1260x1080 | Alpha: No | No Audio PCM:
.mov | DVCPRO HD (25) 1920x1080 DVCPRO HD (29.97) 1260x1080 | Alpha: No | No Audio PCM:
.mxf Panasonic P2 (OP-Atom) | DVCPRO HD (25) 1920x1080 DVCPRO HD (29.97) 1260x1080 | Alpha: No | No Audio |
.mxf (OP1a) | DVCPRO HD (25) 1920x1080 DVCPRO HD (29.97) 1260x1080 | Alpha: No | PCM:
| UADD CS_ENCODER1 * SHAR dart SET U1 MED vtr.media.video.input.compression.type "dvcpro" SET U1 MED vtr.media.mpeg.bit_rate "100000000" SET U1 MED vtr.media.audio.input.channels "8" CUER U1 REC U1 |
Information: Video bitrate is 100, but the encoded bitrate is 115 (15% more) which includes other data.
XDCAM HD 422
.mxf (OP1a) | XDCAM HD 422 1920x1080 | Alpha: No | No Audio PCM:
XDCAM HD LP
.mxf (OP1a) | XDCAM HD LP 1440x1080 | Alpha: No | No Audio PCM:
XDCAM HD SP
.mxf (OP1a) | XDCAM HD SP 1440x1080 | Alpha: No | No Audio PCM:
XDCAM HD HQ
.mxf (OP1a) | XDCAM HD HQ 1440x1080 | Alpha: No | No Audio PCM:
XDCAM EX HQ
.mxf (OP1a) | XDCAM EX HQ 1920x1080 | Alpha: No | No Audio PCM:
AVC-Intra
.mxf (OP1a) | AVCIntra Class 50 1440x1080 | Alpha: No | PCM:
.mxf (OP1a) | AVCIntra Class 100 1920x1080 | Alpha: No | PCM:
.mxf Panasonic P2 (OP-Atom) | AVCIntra Class 50 1440x1080 | Alpha: No | No Audio |
.mxf Panasonic P2 (OP-Atom) | AVCIntra Class 100 1920x1080 | Alpha: No | No Audio |
ProRes
.mov | I-Frame 4:2:2 1920x1080 | Alpha: No | No Audio PCM:
DNxHD
.mxf (OP1a) | DNxHD (30) 120, 185 DNxHD (29.97) 145, 220 1920x1080 | Alpha: No | No Audio PCM:
.mxf (OP1a) | DNxHD (30) 185x DNxHD (29.97) 220x 1920x1080 | Alpha: No | No Audio PCM:
.mxf Panasonic P2 (OP-Atom) | DNxHD (30) 120, 185 DNxHD (29.97) 145, 220 1920x1080 | Alpha: No | No Audio |
.mxf Panasonic P2 (OP-Atom) | DNxHD (30) 185x DNxHD (29.97) 220x 1920x1080 | Alpha: No | No Audio |
XAVC
.mxf (OP1a) | XAVC Intra | Alpha: No | PCM:
1080p50 and 1080p59.94 (60M) Codecs
AVC-Intra
MPEG-IFrame
.avi | MPEG2-IFrame422 1920x1080 | Alpha: No Bitrate: 50-300 Bit depth: 8 VBI: N/A Timecode: N/A TDIR: Yes CC: No | No Audio PCM:
ProRes
DNxHD
.mxf (OP1a) | DNxHD (50) 240, 365 DNxHD (59.94) 290, 440 1920x1080 | Alpha: No | No Audio PCM:
.mxf (OP1a) | DNxHD (50) 365x DNxHD (59.94) 440x 1920x1080 | Alpha: No | No Audio PCM:
.mxf Panasonic P2 (OP-Atom) | DNxHD (50) 240, 365 DNxHD (59.94) 290, 440 1920x1080 | Alpha: No | No Audio |
.mxf Panasonic P2 (OP-Atom) | DNxHD (50) 365x DNxHD (59.94) 440x 1920x1080 | Alpha: No | No Audio |
XAVC
2160p50 and 2160p59.94 (60M) Codecs
XAVC
Note: A M264 board is recommended for recording UHD.
Note: The configuration uhd and v210 must be enabled in the configuration section for recording UHD.
