This section details the installation, configuration and operation of Channel Recorder. Channel Recorder is a service that creates video clips, using an SDI or IP stream as source. It can be controlled using an arbitrary set of commands, or by remote applications utilizing the Multiport Video Computer Protocol (MVCP). The incoming stream is captured into a file.
