The Bar Values plug-in communicates with all Sub-Containers that hold a Bar plug-in and lets you set values for each of them.
Note: This plug-in is located in: Plugins -> Container plug-ins -> Presenter
Bar Values Properties
Num Bars: Sets the number of bars to be controlled by the Bar Values plug-in. Maximum number of bars is 25.
Auto Max: Allows the user to switch between Manual and Auto mode. Auto mode disables the Bar Max value.
Bar Max: Sets the maximum values of the bar.
Bar Min: Sets the minimum value of the bar.
Scale: Sets the scale of the object.
Bar Animation: Sets the number of bars to be animated.
Bar Value 1-25: Sets the value for the bar(s).
To Create a Bar Chart with the Bar Values Plug-in
Add a group container to the scene tree, and add the Bar Values and Grid Arrange to it.
Add a group container as a Sub-Container to the first, and name it
Bar
.Open the Cylinder editor and set Center to
Bottom
.Open the Bar editor, set Param Type to Scale and Scale to
Y
, and click Initialize.Create and place a number of copies of the Bar container (for example,
5
) at the same level as the Bar container.Open the Grid Arrange editor and set Number of Columns to 6 and Column offset to
30.0
.Open the Bar Values editor and set Num Bars to
6
and Bar Animation to6
