The Bar Value plug-in controls the value of all Bar plug-ins and Counters of its child nodes.
In addition, a set of commands can be specified that are executed when the value passes certain thresholds.
Note: This plug-in is located in: Plugins -> Container plug-ins -> Presenter
Bar Value Properties
  • Bar Min: Minimum Value of the bar.
  • Bar Max: Maximum Value of the bar.
  • Value: The actual value of the bar.
  • control counters: States if counters should be affected. If this is checked, Value is shown in all Sub-Containers with Counter plug-ins.
  • Type: Determines whether the command should fire if the threshold is passed from below, or from above. Off does not execute the command at all. Available options are Off, Up and Down.
  • Threshold: Compares the value against the threshold.
  • Command: Executes a Viz Artist/Engine command when the threshold is passed.
To Create a Bar that Shows Its Value
  1. Create a Container and add the Bar Value plug-in to it.
  2. Open the Bar Value editor, and check control counters.
  3. Set Threshold to 20, Type to Up and set a command (for example, MAIN*ONAIR GET_INFO).
  4. Add two Sub-Containers.
  5. Add a Font and a Counter plug-in to the first Sub-Container.
  6. Add a Cube and a Bar plug-in to the second Sub-Container.
  7. Set the Cube’s Y-Axis Center to (B)ottom.
  8. Open the Bar editor and set Param Type to Scale and Scale to Y.
  9. Modify Bar Value’s Value field. If the value exceeds 20 the information is written to the console.
