The Cylinder plug-in creates cylinders with different heights, widths and depths and other attributes.
Cylinder Properties
Use LOD: Enables/disables dynamic level of detail.
Height: Sets the height of the cylinder.
Diameter: Sets the diameter of the cylinder
Rotation: Sets the rotation around X-axis.
Angle: Sets the opening angle from 0-360°. As the value decreases below 360° an increasing angle opens in the cylinder.
Corners: Sets the number of corners the cylinder is to be made up from.
Hole: Creates a hole in the cylinder, making it into a tube.
Center: Sets the position for the center. You can choose between Center, Bottom or Top.
Bevel: Sets the size of bevel at the cylinder.
Inner Bevel: Enables/disables bevel in the cylinder hole if bevel is set at the bevel parameter.
Show Top: Turns off/on visualization of cylinder top.
Show Bottom: Turns off/on visualization of cylinder bottom.
Show size 0: Enables/disables display of the cylinder at height value
0
. If you set height to zero, the cylinder is visible by default. If you disable this option, the cylinder becomes invisible.
To Create a Cylinder
Create a new group container.
Add the Cylinder or Cylinder3 plug-in.
Open the Cylinder editor.
Set Hole to
50.0
.Add a material and/or an image to the same Container.
Open the cylinder editor.
Set Rotation Y to
75.0
and Z to90.0
